Network Management
  • 1.  AirWave Global GROUP
    Posted Jun 22, 2017 05:29 AM
    HI
    I noticed that on Airwave there was the notion of GLOBAL GROUP, to which subgroups could be assigned, thus creating a hierarchy between these groups,
    This means that the subgroups inherit the properties of the GLOBAL GROUP to which they belong !!
    What is the scope of this inheritance, example RADIUS server, SSIDs,
    Have you got  examples or an explanatory doc
  • 2.  RE: AirWave Global GROUP
    Posted Jun 22, 2017 06:27 AM
    We have Global and subscriber group which is used to manage and push the configuraiton to devices.
    Using Global group we could manage the configuraiton changes, if we make any template configuration changes in Global group and click apply, this will autmotically get pushed to subscriber groups.
    All configuration changes need to be done from Global Group only and also we can not add devices to Global Group. We can add gloden template to Global group and edit the configration, this config change will be get pushed to all subscriber groups which have devices added.
    Pavan
    If my post addresses your query give kudos:)
  • 3.  RE: AirWave Global GROUP
    Posted Jun 26, 2017 05:23 AM
    thanks for your answer, does we need to use only Templates or is it possible to manage subscriber group by using GUI
  • 4.  RE: AirWave Global GROUP
    Posted Jun 26, 2017 05:53 AM
    Only template support is availabe in Global and subscriber group mode.
    Pavan
  • 5.  RE: AirWave Global GROUP
    Posted Jun 26, 2017 11:18 AM
    Thanks for the answers
    Is it possible to Modify subscriber group to push spécifics configurations ?
    regards
  • 6.  RE: AirWave Global GROUP
    Posted Jun 26, 2017 11:28 AM
    Yes, we could do for that we need to enable the template check box in Global group template page.
    Regars,
    Pavan
