Currently configuring in openssl is not possible as the root access is locked. We cannot modify accessing Airwave other than 443 and 80.
However, for communication with IAP, we can use alternative ports and this option is present under AMP Setup > Aruba Instant Options.
Regards
Gowri Amujuri
Original Message:
Sent: Mar 23, 2023 11:24 AM
Subject: airwave https on alternative port
Hi
refering to a very very old document : Monitoring, Management & Location Tracking - Airheads Community (arubanetworks.com)
Is it possible to run airwave on alternative port for https - admin access ? So instead of using 443, use i.e. 8443
We also want to keep the access for IAP based on 443 , the webserver must listen to both ports
What is the best way to configure this? Still the same way as the 2014-document ?
Danny Bosman
KBC Group - Belgium
