Network Management
  • 1.  Airwave IAPs Client Blacklisting
    Posted Dec 09, 2015 03:44 AM
    Hi All,
    I'm currently deploying a customer's AMP-8.0.9.2, with IAPs on v6.4.2.6-4.1.1.10_51810.
    We're also using the Instant-GUI-Config in the groups.
    Within the Instant GUI config, I can see the manual blacklist options which is fine.
    Within the client details I can see the deauth button which is fine.
    I can't find an option anywhere to dynamically blacklist a client?
    I assume it's not possible???
  • 2.  RE: Airwave IAPs Client Blacklisting
    Posted Dec 09, 2015 09:16 AM
    What kind of dynamically blacklisting do you need?
    Some types of blacklisting you have in the Instant:
    * add a rule on the role which triggers a client blacklist - for x hours
    * Dynamic blacklist on auth failure for x hours
    You can find triggers for dynamic blacklisting under Security -> Blacklist
  • 3.  RE: Airwave IAPs Client Blacklisting
    Posted Dec 15, 2015 03:13 PM
    You know what, I phrased my question really badly.
    What I was trying to work out, was whether from within Airwave (which is managing IAPs) you could MANUALLY blacklist a client "on the fly". Like with a controller GUI, where you'd just select the client and hit the "blacklist" button.
    I found this old post in Airheads...
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/How-to-kick-a-user-off-WLAN-fro-Airwave-on-a-managed-iAP/td-p/111697
    However, I've tried the "contain" option mentioned in that post, and it doesn't have any affect on the client. I.e. the client just re-auths.
  • 4.  RE: Airwave IAPs Client Blacklisting
    Posted Jan 07, 2016 03:20 PM
    Why wouldn't you navigate to Security -> Blacklisting
    Then add an entry there to manually blacklist.
  • 5.  RE: Airwave IAPs Client Blacklisting
    Posted Jan 15, 2016 02:05 AM
    You/we could.
    It's just not very "slick" is it? Compared to a one-push button.
