First off, clustering target was for setups larger than 20k devices. So any cluster talk should stop since @ 1k, it's complete overkill.
What's the customer requirement for redundancy? What type of devices does the customer have (campus APs, controllers, switches, IAPs)?
If customer just wants redundancy in case of AMP failure, then having 1 AMP and 1 Failover works (both licensed to cover 1k devices). Keep in mind there's a potential 24 hr gap in data depending on time of failure and time of last backup collected.
If customer wants redundancy in an active/active way - they could run 2 AMPs and poll devices twice (or point AMON to both).
If customer has IAPs, the latter option won't work since the IAPs can only point to one AMP at a time. So for instant, would have to designate the secondary AMP server in the settings, and make sure it exists in the whitelist on the 2nd AMP if you're running active. If it's a failover, the restored backup will have the IAPs already in the db.
I've seen customers do both, but the majority go with the AMP & Failover route.
