Network Management
  • 1.  Airwave Rogue APs - How long do they stay on the list
    Posted Oct 03, 2024 10:52 AM
    We introduced hundreds of Rogue APs in the form of Promethean Panels into our school network.  When we noticed them, we started disabling the Wifi Direct settings on the panels, which removed all the SSIDs from the spectrum, but they still show up as rogues in Airwave.  I was hoping to use the Airwave rogue device reports to find any that we had missed, but hundreds are still showing up.  How long will they remain?  Will they age out?  What will happen if I just select them and delete them?  Will any that are still broadcasting show up again?  Or will the delete action delete them forever even if they start broadcasting again?
    Thanks for any guidance
    -Bill
  • 2.  RE: Airwave Rogue APs - How long do they stay on the list
    Posted Oct 03, 2024 02:03 PM
    Edited by Harbor Billy Oct 03, 2024 06:23 PM
    Rogue deletion can be set under RAPIDS > Setup page. Setting the value to zero will disable the function and Rogues will be on the system forever.
    The discovery events can be set under AMP Setup > General > Historical Data retention page
    Discovery events are the events about how a Rogue is detected. They can be lower than Rogue deletion, if you need Rogues to show up longer but no need of their discovery events for same period. When the Rogue ages out or deleted, their discovery events will be deleted automatically.
    For your other queries:
    How long will they remain?  - Based on the retention value under RAPIDS > Setup page. If set to zero, they will remain forever
    Will they age out?  Yes and No, based on the retention value under RAPIDS > Setup page. If set to zero, they will remain forever
    What will happen if I just select them and delete them? Rogue gets deleted along with its discovery events.
    Will any that are still broadcasting show up again?  Yes, if the Rogue is not in AirWave, they show up as new. If its already present, then the discovery events show up.
    Will the delete action delete them forever even if they start broadcasting again?  No, when they are seen on the network again, they will show up in Rogue list.
    Apart from this, I suggest looking at RAPIDS > Setup page for Filtering options, if you see lot of Rogues which are adhoc or with low signal strength. you can set the value accordingly to show up or not, based on the security team/network team needs.
    Also, setup Rogue rules accordingly as per Network/Security team needs.
    Regards
    Gowri Amujuri
  • 3.  RE: Airwave Rogue APs - How long do they stay on the list
    Posted Oct 03, 2024 06:27 PM
    Thanks Gowri. Very clear and complete. Much appreciated.
    -Bill
