A couple of months ago we allowed AMP (Version 7.6.1) to ssh to our controllers so we can run some of the show commands directly from AMP
But we recently noticed in the logs that AMP was running show commands by itself every 15 seconds
10.10.10.5 is the AMP server
May 20 19:58:21 fpcli: USER: admin connected from 10.10.10.5 has logged out.
May 20 19:58:21 fpcli: USER: admin has logged in from 10.10.10.5.
May 20 19:58:21 fpcli: USER:admin@10.10.10.5 COMMAND:<encrypt disable > -- command executed successfully
May 20 19:58:21 fpcli: USER:admin@10.10.10.5 COMMAND:<no paging > -- command executed successfully
May 20 19:58:21 fpcli: USER:admin@10.10.10.5 COMMAND:<show ap provisioning bssid D8:C7:C8:11:22:33 > -- command executed successfully
What scares me the most is that it keeps running the encrypt disable command .
I looked everywhere to see if it is possible to run some sort script from Airwave but I couldn'f find anything .
Is this normal ? Anybody seen this before ?
Vic
