Network Management
AirWave Switch Stacks: No Port Status available for Switch Stacks Commanders
  • 1.  AirWave Switch Stacks: No Port Status available for Switch Stacks Commanders
    Posted Mar 25, 2021 11:47 AM
    I've added our Aruba Switches with the CSV import function with "device type" = "Aruba Switch".
    (I had to learn that AirWave won't detect the correct switch model, if the device type is not defined in the csv file.)
    But AirWave doesn't recognize them as stacks and displays ports only of one member.
    For our 2930M-24SR-PoE+ stack AirWave notice that there are 2 mgmt ports, but only 24 available switch ports.
    Upstream devices and ports are also not detected for the CSV imported stacks.
    Every manually added switch stack works fine. AirWave shows every available ports and the detected upstream device is correct.
    What can I do to fix this?
    Our AirWave servers are running on 8.2.12.1 and our stacks are Aruba 2930M-48G switches.
    The manually added stack and every other stacks are running on the same firmware version.
