Cloud Managed Networks
Airwave to Aruba Central transparent migration
  • 1.  Airwave to Aruba Central transparent migration
    Posted Jun 03, 2019 06:13 AM
    Does anyone know of a document which describes the migration of IAP controlers and devices from Aruba Airwave (8.0.x) to Aruba Central in a transparant fashion with minimum to no downtime required ?
    Serge
  • 2.  RE: Airwave to Aruba Central transparent migration
    Posted Jul 13, 2019 03:32 AM
    No I dont think there is such a document.
    As soon as you get Aruba Central, you can add your IAPs to the Device Inventory or using activate it will automatically show up in Device Inventory.
    Using Aruba Central when you create a new group, you can import the current configuration of the Instant AP's VC, so you can preserve IAP configuration.
