Network Management
Airwave trigger fiber Tx/Rx threshold
  • 1.  Airwave trigger fiber Tx/Rx threshold
    Posted Feb 06, 2019 01:56 PM
    Having problems with some fiber to a particular closet and I'm curious if it's possible to trigger an Airwave alert on low fiber Tx/Rx threshold from a 2920 switch?
    I can log into switch and see things like voltage and tx/rx power status. (below).
    IDF22_HP3800-24# sho interfaces transceiver 25 detail
    Transceiver in 25
      Interface Index    : 25
      Type              : SFP+LR
      Model              : J9151A
      Connector Type    : LC
      Wavelength        : 1310nm
      Transfer Distance  : 10.0km (9um),
      Diagnostic Support : DOM
      Serial Number      : Blahblahblah
     Status
      Temperature : 53.117C
      Voltage    : 3.2668V
      Tx Bias    : 38.442mA
      Tx Power    : 0.4955mW, -3.050dBm
      Rx Power    : 0.4324mW, -3.641dBm
      Time Stamp    : Wed Feb  6 11:43:58 2019
    What I would like to do is have the switch send a trap to airwave if voltage, tx/rx power drops below threshold but I"m just not finding it in ssh session no matter how many ? marks I throw at it.
    If it is possible, the very next question would be what an exceptable range would be. Would there be a difference between LRM and LR? Between 1G and 10G?
    Any info appreciated. Thanks guys !!!
  • 2.  RE: Airwave trigger fiber Tx/Rx threshold
    Posted Feb 13, 2019 12:02 PM
    This would currently be a feature request.  You can open a support case to file the feature request or submit to innovate.arubanetworks.com.
