Network Management
Airwave Upgrade - Currently running 8.2.6
  • 1.  Airwave Upgrade - Currently running 8.2.6
    Posted Jun 04, 2020 04:42 AM
    Hello All
    Im hoping someone can help me with the upgrade path and steps needed to upgrade our Airwave platform.
    Currently we are running - 8.2.6
    As i understand the Upgrade Path would be as follows
    8.2.8.1
    8.2.9
    8.2.11.0
    With at some point having to upgrade the CentOS.
    Could anyone confirm if the above is correct?
    Also how do i check what version of CentOS im currently running?
    Regards
  • 2.  RE: Airwave Upgrade - Currently running 8.2.6
    Posted Jun 04, 2020 06:21 AM
    8.2.6>8.2.7.1>>8.2.9.1>8.2.10.1.>> Take backup of 8.2.10.1and do fresh install of 8.2.10.1 and restore backup >> upgrade to 8.2.11.0.
    Centos migrated to 7 in version 8.2.10. To upgrade to latest code, you have to upgrade server to either 8.2.10 or 8.2.10.1, take backup and do a fresh install and restore same backup and upgrade to latest 8.2.11.0 code.
    Note: 8.2.11.0 supports only Centos7 .
    To check centos version from AMPCLI run  command $crr
    Type 'help' for the list of commands.
    $ crr
    CentOS Linux release 7.7.1908 (Core)
