Network Management
Airwave upgrade to 64bit
  • 1.  Airwave upgrade to 64bit
    Posted Oct 25, 2012 12:16 PM
    I am looking to upgrade our Airwave system to 64bit.  We are currently running v7.3.8 32bit.  I checked all the prerequisites in terms of CPU and what not.  We are a candidate for the upgrade.  I am reading a KB article for instructions (http://www.airwave.com/support/knowledge-base/?sid=50140000000aOby ) .  My question is, do I have to do the upgrade to 64bit using the EXACT same version  we are on (7.3.8 but 64bit)?
  • 2.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 12:38 PM
    Yes, you want to maintain the AMP version during the OS upgrade.  You will want to take your backup off server, reinstall with 7.3.8 64-bit, and then restore the backup.  Once restored, verify that the data has restored properly - check a few you device count, view a few of your devices, check VisualRF, check RAPIDS.  After OS upgrade, you can continue to upgrade AMP as normal (you can upgrade directly to 7.5.6 from 7.3.8).
  • 3.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 12:43 PM
    whats the command to restore the backup?
  • 4.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 01:00 PM
    Here's how to restore a backup if the backup is named nightly_data.tar.gz and it is location in folder /tmp.
    # screen
    Force of habit for any operation that I want to run without monitoring the CLI
    # amp_disable
    Another force of habit, but it makes sure that nothings still writing to the database as you're trying to restore
    # amp_restore -d /tmp/nightly_data.tar.gz
    As restore is going on, I tend to detach myself from the session (in screen, ctrl+a then d).  And then when I want to get back into that screen, if it's the only screen -> 'screen -r', if there are several screens, then you may need to do 'screen -ls' and then 'screen -r ####' where the hash is the pid number.  Once restore completes, it will still be in amp_disable state, so 'amp_enable' and then wait 5-10 minutes for the GUI to become available.
  • 5.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 01:46 PM
    ok, got everything back to normal.  Took a backup and offloaded locally.  Do I just copy the 64bit file to the root and perform start_amp_upgrade from CLI?  the KB article says fresh install?  "Please download the 7.3.8 64 bit ISO image from the link given below and perform a fresh installation:"
  • 6.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 01:57 PM
    Major OS upgrades cannot be done using a simple tarball package.  The OS upgrade path requires you to burn the 7.3.8 64-bit ISO to a CD-rom (though I have heard it's possible to put the ISO onto a thumb-drive).  When you boot off the ISO, it will be like the first time you installed AMP where you run through the same exact steps that are in the Quick Start Guide (support.arubanetworks.com -> documentation -> AirWave -> 7.5.x -> Quick Start Guide).  Once this is done, you'll be good until RHEL / CentOS 7.x.  You'll be able to restore your backup after you complete the ./amp-install and go through the network setup / ssl cert key wizard.  Remember, after the install, the CLI access will be user: root, password: admin.
  • 7.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 10:07 AM
    Did a fresh install, went through quick start, ran ./amp-install, then performed the restore... I can ping the machine and ssh into, however, the Web interface is not working.. http 500 internal server error.
  • 8.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 10:37 AM
    Is there any errors in /var/log/httpd/access_log or error_log?  Are you logging in with a user account local on the AMP or authenticating via RADIUS / LDAP / or TACACS?  If it's the latter, try logging in as a local AMP user, navigate to AMP Setup -> Authentication tab -> reinput the passwords and then logout and try logging in again with an off-server authenticated account.  If that doesn't work, then we can try to do a web meeting and sort through this really quick.
  • 9.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 10:43 AM
    several reboots later and she came up..  however, looking for license
  • 10.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 10:53 AM
    I believe I have found the license file in the backup file
  • 11.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:19 AM
    ok the good news, the licensing is sorted out.  However, doesnt look like the restore worked properly.  All my scan networks groups are gone.  No devices now.. ahhh
  • 12.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:29 AM
    Sounds to me like the restore didn't complete all the way.  Try this to verify:
    # dbc 'select count(*) from ap;'
    This will tell us if the database got fully restored - as the count should be close to the device count (may have some devices that were in the new devices or ignored categories).
    If it's a case that the backup didn't fully restore, then you can try doing the restore process once again.
  • 13.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:31 AM
     count
         4
    (1 row)
    will try the restore again
  • 14.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:38 AM
    [root@leviton mercury]# amp_disable
    DISABLED - 1!!
    [root@leviton mercury]# amp_restore -d databackup.tar.gz
    databackup.tar.gz: not a file
    DISABLED - 1!!
  • 15.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:47 AM
    Which directory did you put the backup file in?  If it wasn't in /tmp or /root, then it might have been overwritten during the restore.
  • 16.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:48 AM
    it was in /tmp, I have the file local as well.  I re-added to root with no luck.. and I moved to tmp with no luck
  • 17.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:50 AM
    Restore command should be:
    # amp_restore -d /tmp/databackup.tar.gz
    You can verify the file exists by issuing the command:
    # file /tmp/databackup.tar.gz
  • 18.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 11:54 AM
    forgot the / before the file name.. its restoring now :)  lets hope everything restores back
  • 19.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 01:41 PM
    seems to be finished?  do I just reboot?
    Stopping postgresql service: [  OK  ]
    postmaster dead but pid file exists
    Starting postgresql service: [  OK  ]
    Converting rrds to 64bit architecture.
    Converting RRDs:   0% [        ]
    Converting RRDs:  16% [===========                                            Converting RRDs:  33% [======================                                 Converting RRDs:  50% [=================================                      Converting RRDs:  66% [============================================           Converting RRDs:  83% [=======================================================Converting RRDs: 100% [=======================================                                                              DISABLED - 1!!
    DISABLED - 1!!
    DISABLED - 1!!
    DISABLED - 1!!
    DISABLED - 1!!
  • 20.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 01:51 PM
    No need to reboot, just issue:
    # amp_enable
    Then give AMP 5-10 minutes to start up the processes.  You can issue the command:
    # watch daemons
    Once the list populates to more than 8 items, the WebUI should become available.
  • 21.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 01:52 PM
    Also, try issuing the db command again to make sure all the devices were restored into the database:
  • 22.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 02:58 PM
    looks like we are back in business.. that restore seemed to get me back to normal.  Now can I upgrade to the latest code?
  • 23.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 04:09 PM
    yeah, should be able to just kick off the upgrade:
    # start_amp_upgrade -v 7.5.6
  • 24.  RE: Airwave upgrade to 64bit
    Posted Oct 26, 2012 04:10 PM
    yep, its in progress.. thanks for all your help!
  • 25.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 12:50 PM
    now receiving this error:  I did not perform the upgrade yet.  I started it, but then aborted it. svn: '/root/svn/mercury' is not a working copy
  • 26.  RE: Airwave upgrade to 64bit
    Posted Oct 25, 2012 12:55 PM
    To fix that:
    # cd /root
    # ls
    Do you see 2 svn directories?  If so:
    # mv svn svn_broke
    # mv svn_old svn
    # cd /root/svn/mercury
    # svn info
    Confirm it's the version you were on (7.3.8)
    For sanity, you may want to refresh the code to make sure it's the running copy:
    # make
    ^^^ above command needs to be run from /root/svn/mercury ^^^
    When running upgrades or backups, I suggest using the unix #screen (kb.airwave.com keyword: screen).  This will ensure that your commands run in the background should you disconnect your laptop / desktop from the network.
