Network Management
  • 1.  AirWave Visual RF requirements.
    Posted Nov 25, 2014 04:32 AM
    Hi Airheads
    I want to find rogue APs in a floor by using Visual RF
    Does it require RFProtect licenes on the controller ?
    I think Visual RF can show the location of each rogue ap, found by RAPIDS.
    RAPIDS is basically used with RFProtect of AurbaOS....
    I want to make clear what I can and cannot  do on Visual RF & RAPIDS without RFProtect license.
  • 2.  RE: AirWave Visual RF requirements.
    Posted Nov 25, 2014 04:40 AM
    It does not require the RF protect license.  No.
  • 3.  RE: AirWave Visual RF requirements.
    Posted Nov 26, 2014 01:30 AM
    Hi Colin
    Thank you for your reply.
    I understood that no licenses are required for displaying rogue APs.
    Does it also mean that all functions of RAPIDS and Visual RF don't require licenses on controller ?
    Thanks in advance.
