Alcatel-Lucent OmniAccess 4750 Mobility Controllers - SFP+
  • 1.  Alcatel-Lucent OmniAccess 4750 Mobility Controllers - SFP+
    Posted Apr 03, 2023 11:23 AM
    Hello all,
    Do you know if it is possible to install Aruba J9150D SFP+ transceivers in an ALE controller / OEM Aruba controller
    Jason
  • 2.  RE: Alcatel-Lucent OmniAccess 4750 Mobility Controllers - SFP+
    Posted Apr 04, 2023 10:36 AM
    That 4750 controller is technically equivalent to the Aruba 7240 (if I'm correct), and the ordering guide for the 7240 mentions that tranceiver as supported with a version restriction of 6.5.3.0+ and 8.1.0.0+.
    Disclaimer: while I expect it to work, you would need to ask Alcatel for a definitive call on this as well for support if it does not work.
