Alcatel oaw-ap1201h accepoint captive portal using clearpass
  • 1.  Alcatel oaw-ap1201h accepoint captive portal using clearpass
    Posted May 14, 2021 01:05 AM
    I have Alcatel oaw-ap1201h accepoint.   Is has ability to use external captive portal. Is it possible to uses clearpass as external captive portal, with self registration, and what service template i should use ?
    Saulius Pabarska
  • 2.  RE: Alcatel oaw-ap1201h accepoint captive portal using clearpass
    Posted May 17, 2021 10:07 AM
    I don't know the OAW-1201H AP; it may be an OEM of another vendor for which you can use the templates for. I would reach out to Alcatel support as they should know the AP and ClearPass as well.
