You can also refer to the developer docs to get started with the APIs in Aruba Central
Presence Streaming APIs:
Location Streaming APIs:
Original Message:
Sent: Jun 22, 2025 02:09 AM
Subject: ALE and AOS10
In AOS10 you have an option to enable sending data from AOS10 APs to ALE server. Didn't use it so far but could be a viable option to get streaming data from AOS10 without advanced subscription if you already have ALE.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Jun 22, 2025 01:59 AM
Hi.
Nor really sure what you mean with ALE controllers. ALE is VM for analytics. The same function in AOS10 is available with Advanced subscriptions and its called Streaming API.
If AP models are supported on Central and AOS10, then you can run it. Check Release Notes. ALE engine is not HW.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Jun 20, 2025 09:25 AM
Hi all,
We have a customer with ALE controllers and APs. They are running Aruba code and are under Aruba support.
would it be possible for this hardware to run AOS10? I'm guessing Activate won't know about them so we may not be able to automatically onboard them into Central.
Jason
