Network Management
AMON prefered over SNMP issues
  • 1.  AMON prefered over SNMP issues
    Posted Apr 18, 2017 10:38 AM
    I needed to disable Prefer AMON over SNMP so some wired usersnames would show up in Airwave. After I did so, the usernames showed up but I noticed a significant drop in users on my clients graph. I sorted by SSID and you can see that only 1 SSID took a hit. The bottom line is the SSID that lost clients as soon as i turned prefer amon off.
    Im having issues figureing out why this is. Any insight?
  • 2.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 10:40 AM
    Do not turn on "preferred Amon".  There is a bug with counting users in some versions of Airwave.  Just turn it off and still send an Amon feed and you should be okay.
  • 3.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 10:45 AM
    Well I looked at the controller and I have more than 150 clients on that last SSID. So why is it reporting such a low number?
  • 4.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 11:26 AM
    We have bug DE22391 in Airwave where RAP wired clients not showing up when we enable prefer AMON over SNMP setting. This issue will be fixed in AMP 8.2.4 and ETA is mid of May.
    I would recommand to enable prefer AMON over SNMP setting.
    Pavan
  • 5.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 11:29 AM
    I dont have any remote access points.
  • 6.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 11:35 AM
    We have DE27808 defect opened for wired device not showing in latest code aswell and this will get address in AMP 8.2.4 along with RAP wired client device.
    Pavan
    If my post address your query give kudos:)
  • 7.  RE: AMON prefered over SNMP issues
    Posted Apr 18, 2017 11:38 AM
    Roger that. Thanks.
  • 8.  RE: AMON prefered over SNMP issues
    Posted Jun 25, 2017 11:35 PM
    With "Preferred AMON" enabled we get AppRF data from the controllers, but the reported number of clients takes a hit.
    With "Preferred AMON" disabled we get NO AppRF data, but the number of reported clients are correct.
    I've got an open support case regarding this...
    Has anyone found a solution to this?
  • 9.  RE: AMON prefered over SNMP issues
    Posted Jun 26, 2017 05:02 AM
    Glen,
    May I know the Airwave version, how much client difference you are seeing when you enable prefer AMON setting?
    Could you share the support ticket number/
    Pavan
  • 10.  RE: AMON prefered over SNMP issues
    Posted Jul 03, 2017 02:27 AM
    Hi
    The case is HPE Support Case 5320795051
    The version is in the case notes. Can’t get to it at the moment on mobile. :(
    Glen
  • 11.  RE: AMON prefered over SNMP issues
    Posted Jul 03, 2017 02:38 AM
    Glen,
    Engineer Ram is working on this ticket, he will drop email to work on this issue today, he mentioned that you requested to keep the case on hold for a week.
    Pavan
  • 12.  RE: AMON prefered over SNMP issues
    Posted Jul 05, 2017 12:25 AM
    Aruba Support indicate our issue is related to our Mobility Controllers v6.5.13 and Airwave v8.2.2
