  • 1.  Android Onboarding with QuickConnect
    Posted Jul 15, 2018 06:57 AM
    Hello All,
    We have an open network where users initially connect to onboard their devices.
    I have allowed access to the below URLs so users can download the quickconnect APP for the playstore, the issue is some users can and some can't.
     *.ggpht.com
    *.play.googleapis.com
    *.gvt1.com
    www.googleapis.com
    android.clients.google.com
    play.google.com
    Another problem is when allowing these URLs, users can access youtube through the APP !!!
    is there anyway to resolve this issue ?
    also if there is a way to upload the APK on clearpass and change the download URL in the onboard page to go to clearpass instead of the google play
  • 2.  RE: Android Onboarding with QuickConnect
    Posted Jul 15, 2018 10:04 AM
    Be sure you're using the most up to date list.
    https://github.com/aruba/clearpass-cloud-service-whitelists/blob/master/onboard/onboard_android.md
    Due to the way Google has implemented their CDNs, some Google sites will be accessible.
  • 3.  RE: Android Onboarding with QuickConnect
    Posted Jul 15, 2018 10:15 AM
    Thanks so much for the reply.
    I will try and test it out and let you know, but is there a way to block youtube as well ?
    and do you recommend uploading the APK to clearpass and customizing the page to download locally from clearpass (lot of work and no documentation) ?
  • 4.  RE: Android Onboarding with QuickConnect
    Posted Jul 15, 2018 10:17 AM
    No you can't.
    Uploading the APK is not recommended as users have to bypass security restrictions on their device. Please do not do this.
  • 5.  RE: Android Onboarding with QuickConnect
    Posted Jul 15, 2018 10:20 AM
    Ok sounds good, will not think about the APK thing.
    I know not aruba issue, google way but youtube access before authenticating is really disappointing.
