  • 1.  Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 13 days ago
    Hello, we are having issue's connecting Android Mobile Phones to our corporate Wi-Fi Network.
    Our Sophos MDM config
    Trusted certificate: internal Root CA
    Domain suffix match: Our Domainname
    The Errors in clearpass
    only Android Mobile Phones can´t connect. iOS Devices are fine
  • 2.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 13 days ago
    The root CA used on the client is the same root CA that signed the RADIUS certificate on ClearPass?
    Carson Hulcher, ACEX#110
  • 3.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 11 days ago
    Yes, it´s the same
  • 4.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 11 days ago
    Is that trusted certificate field specifying the RADIUS certificate on ClearPass?  Have your Android devices been configured to use the root CA of the RADIUS certificate as a trusted root?
  • 5.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 10 days ago
    Yes it´s the same as = Administration > Certificates > Trust List
    In the Wifi Settings is the ca-certificate shown and selected.
  • 6.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 11 days ago
    The messages in ClearPass refer to EAP-TLS failing, your MDM configures PEAP/MSCHAPv2. Could that be part of the issue? What is is what you try to configure and can you share the ClearPass service authentication methods and sources?
    Note that PEAP/MSCHAPv2 is deprecated. As you entered probably dummy credentials that are not used for anything else, that may be acceptable. But you should consider EAL-TLS with a client certificate otherwise.
  • 7.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 10 days ago
    I think not. The same configuration works with ios devices and mschapv2 authentication.
    there are credentials from an service account only for wlan authentication
  • 8.  RE: Android Smartphone -> TLS Alert read:fatal:internal error / rlm_eap_tls: TLS failed during operation
    Posted 10 days ago
    Android will not complete the authentication if the device hasn't been configured with a proper trusted root CA for the RADIUS certificate.  Since that is the only certificate that should be involved when using PEAP/MS-CHAPv2, I'd make sure that everything is properly configured on the client side with that certificate.
