Developer
Ansible error, unterminated character set at position 0
This thread has been viewed 147 times
higher_ed_admin_0978734512
higher_ed_admin_0978734512Jul 08, 2021 08:37 AM
  • 1.  Ansible error, unterminated character set at position 0
    Posted Jun 23, 2021 01:38 PM
    Edited by higher_ed_admin_0978734512 Jun 23, 2021 01:38 PM
    Has anyone seen this error recently?
    Running the playbook with -vvvv I get:
    The full traceback is:
    File "/tmp/ansible_aoscx_config_payload_9q0pzltx/ansible_aoscx_config_payload.zip/ansible/module_utils/aoscx.py", line 397, in run_commands
    return conn.run_commands(commands=commands, check_rc=check_rc)
    File "/tmp/ansible_aoscx_config_payload_9q0pzltx/ansible_aoscx_config_payload.zip/ansible/module_utils/connection.py", line 195, in __rpc__
    raise ConnectionError(to_text(msg, errors='surrogate_then_replace'), code=code)
    fatal: [test-sw.colgate.edu]: FAILED! => changed=false
    invocation:
    module_args:
    after: null
    backup: false
    backup_options: null
    before: null
    diff_against: null
    diff_ignore_lines: null
    intended_config: null
    lines: null
    match: line
    parents: null
    provider: null
    replace: line
    running_config: null
    save_when: modified
    src: null
    msg: unterminated character set at position 0​
    I recently upgrade to arubanetworks.aoscx_role (3.0.0)
    $ ansible --version
    ansible [core 2.11.1]
    config file = /etc/ansible/ansible.cfg
    configured module search path = ['/home/user/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
    ansible python module location = /home/user/.local/lib/python3.8/site-packages/ansible
    ansible collection location = /home/user/.ansible/collections:/usr/share/ansible/collections
    executable location = /home/user/.local/bin/ansible
    python version = 3.8.5 (default, May 27 2021, 13:30:53) [GCC 9.3.0]
    jinja version = 2.10.1
    libyaml = True
    Non-AOSCX (role) based playbooks work without issue.
    Don Rhodes
  • 2.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 25, 2021 07:21 AM
    Hi Don,
    Do you have update also pyaos module ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 27, 2021 05:11 PM
    Damm even I am having a similar kind of issue, I have searched all over the internet and even have posted on number of threads on different forum, no solution seems to work. I am really frustrated, can anyone of you here help me resolve this issue, I am very much tired now.
    Shubhampaul Shubhampaul
  • 4.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 28, 2021 06:57 AM
    do you have check the pyaoscx release ?
  • 5.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 29, 2021 01:48 PM
    Edited by Jamie E Jun 30, 2021 10:49 AM
    Can you share your version of your ansible collection (ansible-galaxy collection list)
    Because I suspect the issue comes from the ansible.netcommon
  • 6.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 29, 2021 01:21 AM
    Hi all,
    I've seen this error with multiple versions of Ansible installed (through a package installer as well as through a pip install). Can you ensure only 1 version of Ansible exists and try executing again?
    Through package installer (Ubuntu):
    `apt list --installed `
    Through pip:
    `python3 -m pip list`
    Ensure there's only 1 ansible-base or ansible-core according to Ansible's documentation.
    For instructions on how to install Ansible refer to their documentation here:
    Tiffany Chiapuzio-Wong
  • 7.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 30, 2021 10:51 AM
    Tiffany, I got the same error when i use ansible 3( ansible-base) or 4(ansible-core), working with aoscx role.
    but it works when I use 2.9.23, for the same playbook. (btw ansible built-in module, like debug works)
    (ansible1) root@ubuntu:/home/student/test/product# python3 -m pip list
    Package Version ------------- ---------
    ansible 3.0.0
    ansible-base 2.10.11
    bcrypt 3.2.0
    certifi 2021.5.30
    cffi 1.14.5 chardet 4.0.0 cryptography 3.4.7
    idna 2.10
    Jinja2 3.0.1
    MarkupSafe 2.0.1
    packaging 20.9
    paramiko 2.7.2
    pip 20.0.2
    pkg-resources 0.0.0
    pyaoscx 2.0.0
    pycparser 2.20
    PyNaCl 1.4.0
    pyparsing 2.4.7
    PyYAML 5.4.1
    requests 2.25.1
    resolvelib 0.5.4
    setuptools 44.0.0 six 1.16.0 urllib3 1.26.6
    Kevin Zhu
  • 8.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 30, 2021 10:52 AM
    I got same error when i use ansible3 or 4 working with ansible aoscx ssh module.
    for my case:
    1. 2.9.23, everything including ssh/httpapi/built-in modules working good
    2. ansible 3(ansible-base 2.10) or ansible 4(ansible-core):
       1. built-in module works
       2. httpapi modules works
       3. network_cli, ssh module not working.
    btw, there is only one ansible-base or ansible-core was running.
    Kevin Zhu
  • 9.  RE: Ansible error, unterminated character set at position 0
    Posted Jun 30, 2021 02:33 PM
    Edited by Tiffany.Chiapuzio-Wong Jun 30, 2021 02:34 PM
    Which python version are you using? Are you running this in a docker container at all?
    In my experience when using the new Ansible versions (3/4) python 3.8 is required.
  • 10.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 07, 2021 11:52 AM
    Sorry for the long delay in responding.
    I started out with 'two version of Ansible installed':
    ~$ apt list --installed | grep ansible
    ansible/focal,now 2.9.6+dfsg-1 all [installed]
    ~$ python3 -m pip list | grep ansible
    ansible                            4.0.0
    ansible-core                       2.11.1
    So I removed all of it:
    pip uninstall ansible
    pip uninstall ansible-core
    sudo apt remove ansible​
    I installed it via APT, I am using Ubuntu 20.04.2 LTS   Windows Subsystem for Linux.
    sudo apt update
    sudo apt install software-properties-common
    sudo add-apt-repository --yes --update ppa:ansible/ansible
    sudo apt install ansible​
    I received the following error after installing it:
    ~$ ansible --version
    -bash: /home/user/.local/bin/ansible: No such file or directory​
    So i removed it and installed it via PIP, and it runs this time:
    ansible [core 2.11.2]
      python version = 3.8.10 (default, Jun  2 2021, 10:49:15) [GCC 9.4.0]
      libyaml = True
    However the playbook still runs with the original error.
    Package                            Version
    ansible                            4.2.0
    ansible-core                       2.11.2
    attrs                              19.3.0
    Automat                            0.8.0
    bcrypt                             3.2.0
    blinker                            1.4
    certifi                            2019.11.28
    cffi                               1.14.3
    chardet                            3.0.4
    Click                              7.0
    cloud-init                         21.2
    colorama                           0.4.3
    command-not-found                  0.3
    configobj                          5.0.6
    constantly                         15.1.0
    cryptography                       2.8
    dbus-python                        1.2.16
    decorator                          4.4.2
    distro                             1.4.0
    distro-info                        0.23ubuntu1
    entrypoints                        0.3
    httplib2                           0.14.0
    hyperlink                          19.0.0
    idna                               2.8
    importlib-metadata                 1.5.0
    incremental                        16.10.1
    Jinja2                             2.10.1
    jsonpatch                          1.22
    jsonpointer                        2.0
    jsonschema                         3.2.0
    keyring                            18.0.1
    language-selector                  0.1
    launchpadlib                       1.10.13
    lazr.restfulclient                 0.14.2
    lazr.uri                           1.0.3
    lxml                               4.6.3
    MarkupSafe                         1.1.0
    more-itertools                     4.2.0
    netifaces                          0.10.4
    nftables                           0.1
    nsx-policy-python-sdk              3.0.3.0.0.17723277
    nsx-python-sdk                     3.0.3.0.0.17723277
    nsx-vmc-aws-integration-python-sdk 3.0.3.0.0.17723277
    nsx-vmc-policy-python-sdk          3.0.3.0.0.17723277
    oauthlib                           3.1.0
    packaging                          20.9
    paramiko                           2.7.2
    pexpect                            4.6.0
    pip                                20.0.2
    pyaoscx                            2.0.0
    pyasn1                             0.4.2
    pyasn1-modules                     0.2.1
    pycparser                          2.20
    pycrypto                           2.6.1
    PyGObject                          3.36.0
    PyHamcrest                         1.9.0
    PyJWT                              1.7.1
    PyNaCl                             1.4.0
    pyOpenSSL                          19.0.0
    pyparsing                          2.4.7
    pyrsistent                         0.15.5
    pyserial                           3.4
    python-apt                         2.0.0+ubuntu0.20.4.5
    python-debian                      0.1.36ubuntu1
    pyvmomi                            7.0.1
    PyYAML                             5.3.1
    requests                           2.22.0
    requests-unixsocket                0.2.0
    resolvelib                         0.5.4
    SecretStorage                      2.3.1
    selinux                            3.0
    service-identity                   18.1.0
    setuptools                         45.2.0
    simplejson                         3.16.0
    six                                1.14.0
    slip                               0.6.5
    slip.dbus                          0.6.5
    sos                                4.1
    ssh-import-id                      5.10
    suds-jurko                         0.6
    systemd-python                     234
    Twisted                            18.9.0
    ubuntu-advantage-tools             27.0
    ufw                                0.36
    unattended-upgrades                0.1
    urllib3                            1.25.8
    vapi-client-bindings               3.5.0
    vapi-common-client                 2.19.0
    vapi-runtime                       2.19.0
    vmc-client-bindings                1.36.0
    vmc-draas-client-bindings          1.17.0
    vSphere-Automation-SDK             1.51.0
    wadllib                            1.3.3
    wheel                              0.34.2
    zipp                               1.0.0
    zope.interface                     4.7.1
    ~$ python --version
    Python 2.7.18
    ~$ python3 --version
    Python 3.8.10
    Don Rhodes
  • 11.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 07, 2021 06:08 PM
    Can you try updating the netcommon collection and see if that changes your output?
    `ansible-galaxy collection install ansible.netcommon -f`
  • 12.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 08, 2021 08:23 AM
    Edited by higher_ed_admin_0978734512 Jul 08, 2021 08:45 AM
    Here is the output:
    :~$ ansible-galaxy collection install ansible.netcommon -f
    Starting galaxy collection install process
    Process install dependency map
    Starting collection install process
    Downloading https://galaxy.ansible.com/download/ansible-netcommon-2.2.0.tar.gz to /home/user/.ansible/tmp/ansible-local-18385k64umbn7/tmp3g9bgmm8/ansible-netcommon-2.2.0-868w6ert
    Installing 'ansible.netcommon:2.2.0' to '/home/user/.ansible/collections/ansible_collections/ansible/netcommon'
    ansible.netcommon:2.2.0 was installed successfully
    Skipping 'ansible.utils:2.2.0' as it is already installed​
    In case this is helpful
    :~$ ansible-galaxy collection list
    # /home/user/.ansible/collections/ansible_collections
    Collection          Version
    ansible.netcommon   2.2.0
    ansible.utils       2.2.0
    arubanetworks.aoscx 2.1.1
    cisco.ios           1.1.0
    # /home/user/.local/lib/python3.8/site-packages/ansible_collections
    Collection                    Version
    amazon.aws                    1.5.0
    ansible.posix                 1.2.0
    ansible.utils                 2.3.0
    ansible.windows               1.7.0
    arista.eos                    2.2.0
    awx.awx                       19.2.2
    azure.azcollection            1.7.0
    check_point.mgmt              2.0.0
    chocolatey.chocolatey         1.1.0
    cisco.aci                     2.0.0
    cisco.asa                     2.0.2
    cisco.intersight              1.0.15
    cisco.ios                     2.3.0
    cisco.iosxr                   2.3.0
    cisco.meraki                  2.4.2
    cisco.mso                     1.2.0
    cisco.nso                     1.0.3
    cisco.nxos                    2.4.0
    cisco.ucs                     1.6.0
    cloudscale_ch.cloud           2.2.0
    community.aws                 1.5.0
    community.azure               1.0.0
    community.crypto              1.7.1
    community.digitalocean        1.7.0
    community.docker              1.8.0
    community.fortios             1.0.0
    community.general             3.3.0
    community.google              1.0.0
    community.grafana             1.2.1
    community.hashi_vault         1.3.0
    community.hrobot              1.1.1
    community.kubernetes          1.2.1
    community.kubevirt            1.0.0
    community.libvirt             1.0.1
    community.mongodb             1.2.1
    community.mysql               2.1.0
    community.network             3.0.0
    community.okd                 1.1.2
    community.postgresql          1.3.0
    community.proxysql            1.0.0
    community.rabbitmq            1.0.3
    community.routeros            1.2.0
    community.skydive             1.0.0
    community.sops                1.1.0
    community.vmware              1.11.0
    community.windows             1.5.0
    community.zabbix              1.3.0
    containers.podman             1.6.1
    cyberark.conjur               1.1.0
    cyberark.pas                  1.0.7
    dellemc.enterprise_sonic      1.1.0
    dellemc.openmanage            3.5.0
    dellemc.os10                  1.1.1
    dellemc.os6                   1.0.7
    dellemc.os9                   1.0.4
    f5networks.f5_modules         1.10.1
    fortinet.fortimanager         2.1.2
    fortinet.fortios              2.1.1
    frr.frr                       1.0.3
    gluster.gluster               1.0.1
    google.cloud                  1.0.2
    hetzner.hcloud                1.4.3
    hpe.nimble                    1.1.3
    ibm.qradar                    1.0.3
    infinidat.infinibox           1.2.4
    inspur.sm                     1.2.0
    junipernetworks.junos         2.3.0
    kubernetes.core               1.2.1
    mellanox.onyx                 1.0.0
    netapp.aws                    21.2.0
    netapp.azure                  21.7.0
    netapp.cloudmanager           21.7.0
    netapp.elementsw              21.6.1
    netapp.ontap                  21.7.0
    netapp.um_info                21.6.0
    netapp_eseries.santricity     1.2.13
    netbox.netbox                 3.1.1
    ngine_io.cloudstack           2.1.0
    ngine_io.exoscale             1.0.0
    ngine_io.vultr                1.1.0
    openstack.cloud               1.5.0
    openvswitch.openvswitch       2.0.0
    ovirt.ovirt                   1.5.3
    purestorage.flasharray        1.8.0
    purestorage.flashblade        1.6.0
    sensu.sensu_go                1.11.1
    servicenow.servicenow         1.0.6
    splunk.es                     1.0.2
    t_systems_mms.icinga_director 1.18.0
    theforeman.foreman            2.1.1
    vyos.vyos                     2.3.1
    wti.remote                    1.0.1​
    Don Rhodes
  • 13.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 08, 2021 08:37 AM
    Edited by higher_ed_admin_0978734512 Jul 08, 2021 08:44 AM
    delete this port
  • 14.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 08, 2021 02:14 PM
    Still the same error message?
  • 15.  RE: Ansible error, unterminated character set at position 0
    Posted Jul 08, 2021 04:53 PM
    Yes.
    ~$ ansible-playbook --vault-password-file ~/.ansible/ansible-aoscx-passwordfile -i ~/ansible_git/playbooks/aoscx/ansible-aoscx-inventory.yml ~/ansible_git/playbooks/aoscx/dev/ansible-aoscx-save-config.yml
    PLAY [Testing] **********************************************************************************************************************************
    TASK [Save and backup running-configuration] ****************************************************************************************************
    included: /home/user/ansible_git/playbooks/aoscx/tasks/ansible-aoscx-task-save-and-copy-config-to-tftp.yml for test1-office-sw.colgate.edu, test2-office-sw.colgate.edu
    TASK [__INCLUDED_TASK__ Save the running-config] ************************************************************************************************
    fatal: [test2-office-sw.colgate.edu]: FAILED! => changed=false
    fatal: [test1-office-sw.colgate.edu]: FAILED! => changed=false
    PLAY RECAP **************************************************************************************************************************************
    test1-office-sw.colgate.edu  : ok=1    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0
    test2-office-sw.colgate.edu  : ok=1    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0​
    Don Rhodes
  • 16.  RE: Ansible error, unterminated character set at position 0
    Posted Aug 11, 2021 04:27 PM
    I was getting the issue , using a virtualenv and installing the latest ansible release through pip install.
    Recreating my virtualenv, and forcing a release of ansible < 2.10 corrected this issue.
    pip install ansible==2.9.24
    Tangi CURET
  • 17.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 03:21 AM
    For my case I have exactly the same error message when I run my playbook : unterminated character set at position 0
    My collection version info :
    ansible.netcommon 2.1.0
    ansible.utils 2.3.0
    arubanetworks.aoscx 3.0.1
    Ansible version :
    ansible 2.10.4
    ansible-base 2.10.3
    As you can see, I have updated at the last version of the aruba collection , I have also tried to update the ansible.netcommon and ansible.utils but this did not solve the problem..
    But when I downgrade my ansible.netcommon at the version 1.4.1 it works well.
    ansible.netcommon 1.4.1
    ansible.utils 2.4.1
    On your side, can you run a playbook in the latest version of netcommon ? if yes how did you solve the issue.
  • 18.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 08:56 AM
    do you have check with verbose ?
  • 19.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 09:15 AM
    Yes, bellow the result :
    File "/tmp/ansible_aoscx_command_payload_nwnvdd07/ansible_aoscx_command_payload.zip/ansible_collections/arubanetworks/aoscx/plugins/module_utils/aoscx.py", line 402, in run_commands
    File "/tmp/ansible_aoscx_command_payload_nwnvdd07/ansible_aoscx_command_payload.zip/ansible/module_utils/connection.py", line 195, in __rpc__
    fatal: [MYHOST]: FAILED! => {
    "changed": false,
    "invocation": {
    "module_args": {
    "commands": [
    "show run"
    "interval": 1,
    "match": "all",
    "output_file": null,
    "output_file_format": "json",
    "provider": null,
    "retries": 10,
    "wait_for": null
    "msg": "unterminated character set at position 0"
  • 20.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 11:06 AM
    Hi @mrrobot ! We've opened up an issue on Ansible's Github regarding the netcommon collection and another issue we've bene seeing with the CLI modules - Are you stating that when you downgrade to `netcommon==1.4.1` everything works as expected?
    The issue on Ansible's Github: https://github.com/ansible-collections/ansible.netcommon/issues/301
  • 21.  RE: Ansible error, unterminated character set at position 0
    Posted Oct 06, 2021 02:53 AM
    Hi @Tiffany.Chiapuzio-Wong, yes exactly.
  • 22.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 02:47 PM
    get the same error running playbooks: "unterminated character set at position 0"
    $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Debian
    Description: Debian GNU/Linux 11 (bullseye)
    Release: 11
    Codename: bullseye
    $ python3 -V
    Python 3.9.2
    Package Version
    ansible 4.6.0
    ansible-core 2.11.5
    ansible-pylibssh 0.2.0
    attrs 21.2.0
    bcrypt 3.2.0
    certifi 2021.5.30
    cffi 1.14.6
    charset-normalizer 2.0.6
    cryptography 3.4.8
    future 0.18.2
    idna 3.2
    Jinja2 3.0.1
    jsonschema 4.0.0
    jxmlease 1.0.3
    lxml 4.6.3
    MarkupSafe 2.0.1
    ncclient 0.6.12
    netaddr 0.8.0
    packaging 21.0
    paramiko 2.7.2
    pip 20.3.4
    pkg-resources 0.0.0
    pyaoscx 2.0.1
    pycparser 2.20
    PyNaCl 1.4.0
    pyparsing 2.4.7
    pyrsistent 0.18.0
    PyYAML 5.4.1
    requests 2.26.0
    resolvelib 0.5.4
    setuptools 44.1.1
    six 1.16.0
    textfsm 1.1.2
    ttp 0.8.0
    urllib3 1.26.7
    wheel 0.34.2
    xmltodict 0.12.0
    $ ansible --version
    ansible [core 2.11.5]
    config file = /home/user/ansible/ansible.cfg
    ansible python module location = /home/user/ansible/lib/python3.9/site-packages/ansible
    executable location = /home/user/ansible/bin/ansible
    python version = 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
    jinja version = 3.0.1
    libyaml = True
    Collection Version
    ansible.netcommon 2.4.0
    ansible.utils 2.4.1
    arubanetworks.aos_switch 1.4.0
    # /home/user/ansible/lib/python3.9/site-packages/ansible_collections
    Collection Version
    ansible.posix 1.3.0
    ansible.utils 2.4.0
    ansible.windows 1.7.2
    Philipp Brenzinger
  • 23.  RE: Ansible error, unterminated character set at position 0
    I get the same error running playbooks: "unterminated character set at position 0
    Python3 in virtualenviroment with fresh install yesterday on Debian 11.
    $ lsb_release -a
    Release: 11
    Codename: bullseye
    $ python3 -V
    Python 3.9.2
    Package Version
    ansible 4.6.0
    ansible-core 2.11.5
    attrs 21.2.0
    bcrypt 3.2.0
    certifi 2021.5.30
    cffi 1.14.6
    cryptography 3.4.8
    future 0.18.2
    idna 3.2
    Jinja2 3.0.1
    jsonschema 4.0.0
    jxmlease 1.0.3
    lxml 4.6.3
    MarkupSafe 2.0.1
    ncclient 0.6.12
    netaddr 0.8.0
    packaging 21.0
    paramiko 2.7.2
    pip 20.3.4
    pkg-resources 0.0.0
    pyaoscx 2.0.1
    pycparser 2.20
    PyNaCl 1.4.0
    pyparsing 2.4.7
    pyrsistent 0.18.0
    PyYAML 5.4.1
    requests 2.26.0
    resolvelib 0.5.4
    setuptools 44.1.1
    six 1.16.0
    textfsm 1.1.2
    ttp 0.8.0
    urllib3 1.26.7
    wheel 0.34.2
    xmltodict 0.12.0
    $ ansible --version
    libyaml = True
    Collection Version
    ansible.utils 2.4.1
    Collection Version
    amazon.aws 1.5.1
    ansible.posix 1.3.0
    ansible.utils 2.4.0
    arista.eos 2.2.0
    awx.awx 19.2.2
    azure.azcollection 1.9.0
    cisco.aci 2.0.0
    cisco.asa 2.0.3
    cisco.intersight 1.0.17
    cisco.ios 2.4.0
    cisco.iosxr 2.4.0
    cisco.meraki 2.4.2
    cisco.mso 1.2.0
    cisco.nso 1.0.3
    cisco.nxos 2.5.1
    cisco.ucs 1.6.0
    community.aws 1.5.0
    community.crypto 1.9.3
    community.digitalocean 1.10.0
    community.docker 1.9.1
    community.general 3.7.0
    community.grafana 1.2.3
    community.hashi_vault 1.3.2
    community.libvirt 1.0.2
    community.mongodb 1.3.1
    community.mysql 2.1.1
    community.okd 1.1.2
    community.postgresql 1.4.0
    community.proxysql 1.2.0
    community.rabbitmq 1.1.0
    community.vmware 1.14.0
    community.windows 1.6.0
    community.zabbix 1.4.0
    containers.podman 1.8.0
    cyberark.pas 1.0.7
    dellemc.openmanage 3.6.0
    dellemc.os10 1.1.1
    dellemc.os6 1.0.7
    dellemc.os9 1.0.4
    f5networks.f5_modules 1.11.1
    fortinet.fortimanager 2.1.3
    fortinet.fortios 2.1.2
    frr.frr 1.0.3
    gluster.gluster 1.0.2
    google.cloud 1.0.2
    hetzner.hcloud 1.6.0
    hpe.nimble 1.1.3
    ibm.qradar 1.0.3
    inspur.sm 1.3.0
    junipernetworks.junos 2.5.0
    mellanox.onyx 1.0.0
    netapp.aws 21.6.0
    netapp.azure 21.9.0
    netapp.cloudmanager 21.10.0
    netapp.ontap 21.11.0
    netapp.um_info 21.7.0
    netbox.netbox 3.1.2
    openstack.cloud 1.5.1
    ovirt.ovirt 1.6.3
    purestorage.flasharray 1.10.0
    sensu.sensu_go 1.12.0
    splunk.es 1.0.2
    t_systems_mms.icinga_director 1.22.0
    theforeman.foreman 2.2.0
    vyos.vyos 2.5.1
    wti.remote 1.0.1
  • 24.  RE: Ansible error, unterminated character set at position 0
    Posted Sep 30, 2021 02:48 PM
    I got the same Error. Downgrading to ansible 2.9.26 fixed it. Thx!
    Error Messages:
    • unterminated character set at position 0
    • Unable to decode JSON from response to exec_command('show running-config'). Received 'None'.
  • 25.  RE: Ansible error, unterminated character set at position 0
    Posted Oct 01, 2021 03:48 PM
    Everyone having this issue - can you please confirm if downgrading your `ansible.netcommon` collection to version 1.4.1 resolves the issue on Ansible version 2.10+?
    ansible-galaxy collection install ansible.netcommon:1.4.1 -f
  • 26.  RE: Ansible error, unterminated character set at position 0
    Posted Oct 06, 2021 06:10 AM
    It resolved my issue as well.  I do get this though:  "[WARNING]: Collection ansible.netcommon does not support Ansible version 2.11.2"
    Don Rhodes
  • 27.  RE: Ansible error, unterminated character set at position 0
    Posted Nov 02, 2021 06:34 PM
    i can confirm that using the following command helped me solving the problem :
    colab bokarov
  • 28.  RE: Ansible error, unterminated character set at position 0
    Posted Dec 09, 2021 02:56 PM
    Hello!
    I'm happy to announce a fix for this issue has been published and you can now pull the latest version of our Collection to verify:
    `ansible-galaxy collection install arubanetworks.aoscx -f`
    Also ensure you're working with the most updated version of the `ansible.netcommon` library as well:
    Please let us know if you run into any further issues!!
