Hi Guys
I haven't had much experience with external antennas , I am using
AP 314 With 4 (AP-ANT-1W 2.4-2.5GHz (4dBi)/4.9-5.875GHz (6dBi) Hi Gain Dual-band Omni-Dir Indoor Antenna) , i have some difficulty to configure antenna gain while AP provision , I mounting AP along the walls (see attached) to provide room coverage , problem that the wall material is concrete or cinder block? I've read that mounting APs against the wall can be bad, especially if the material is reflective
I tried to provision ap with max antenna gain but i got leak on coverage (Hope any body can help on this )
The second problem that all My AP (314,303H) is showing flag r which is mean the antenna on power restricted mode as well the power led is amber which strange for me , i am using cisco 2960 POE switch and some other Cisco switches with POE plus
