  • 1.  Any way to export triggers in CSV format??
    Posted Jul 31, 2013 08:51 AM
    Is there any way to export the triggers in CSV or some other format.
    We are planning to review how each triggers is configured and with 9 AMP servers with at least 15-20 triggers per appliance, this gets CRAZY when looking through each one and its configuration????
  • 2.  RE: Any way to export triggers in CSV format??
    Posted Jul 31, 2013 10:52 AM
    There's not a good way from the UI, and the CLI will leave you chasing IDs through different tables.  Database tables involved with triggers: trigger, trigger_condition, ap_group, ap_folder, role.  This is another feature request worth submitting to the ideas portal.
  • 3.  RE: Any way to export triggers in CSV format??
    Posted Jul 31, 2013 11:17 AM
    ya I figured. Thanks Rob.
    Will submit the idea.
    EDIT: (link to idea)
    https://arubanetworkskb.secure.force.com/prm/ideas/viewIdea.apexp?id=08740000000LDm9
