ok this means that this AP is not managed by Aruba Central.
Original Message:
Sent: Jul 25, 2023 10:38 PM
Subject: Anyone Noticing Weird Problems with Central Managed AP's?
Thanks for that info. I have 2 AP's that have failed. I can't really do any troubleshooting on the factory-reset AP because as I said, it's in a reboot-loop so it's never up for long enough.
I have another AP that has the original problem I described though, that is, if they're power-cycled they lose all config. I can still SSH to that one and was able to run the show ap debug cloud-server, which returns this:
IAP mgmt mode :local-mgmt
cloud config recved :FALSE
state diff :disable
Device Cert status :SUCCESS
I'm unclear on what that means though.
Thanks.
__________________
Hal Douglas
IT Manager & Project Specialist
Marist Regional College
Work: (03) 6432 7624
Website: www.mrc.tas.edu.au
Notice: The information contained in this e-mail message and any attached files may be confidential information.If you are not the intended recipient any use, disclosure or copying of this e-mail is unauthorised. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and delete all copies of this transmission together with any attachments.
Original Message:
Sent: 7/25/2023 10:20:00 PM
Subject: RE: Anyone Noticing Weird Problems with Central Managed AP's?
When an AP in factory-default mode powers on and connects to the Internet, it will automatically check into Aruba Activate using Websocket.
It is activate that will direct the AP to connect to Central by providing the correct URL.
do you use activate service and do you have any rules in it?
if not the "show ap debug cloud-server" could provide more clues.
Original Message:
Sent: Jul 25, 2023 08:43 PM
Hi again all,
Further to this - we have verified it's nothing to do with our firewall or network. Here's what we did:
- Connect one of the failed AP's to the ethernet port on a 4G hotspot (so it's not connected to our network at all, not behind our firewall or even using the same ISP).
- Connect a console cable to the AP mentioned above.
- Factory reset the AP mentioned above using the reset hole on the back.
- Watch what happens.
The console shows a reset is confirmed. My understanding is that the AP should then contact Central and get a config, but it doesn't. It in fact goes into a reboot loop.
Any thoughts?
Thanks.
Original Message:
Sent: Jul 25, 2023 02:47 AM
@ariyap - the firewall was one of the first places we looked (the other being recent changes to the AP group). There had been no changes in or around the timeframe of the problem beginning. We can see traffic going through the firewall so it seems okay (we also have made no recent changes on the AP group either).
Firmware version is 8.6.0.9_79813 on all of them.
Thanks.
Original Message:
Sent: Jul 25, 2023 02:36 AM
were there any changes on the LAN side or your firewall lately?
also what firmware are you running? is it AOS10?
Original Message:
Sent: Jul 25, 2023 02:20 AM
Hi all,
We've experienced some very weird things from Central in the past couple of days and I was wondering if anyone else has?
We have 70-odd AP's (almost all 315's) that are managed through Central which has been great for the last 4 years we've had them but yesterday they seem to have almost all started misbehaving. We're still investigating - with the help of HPE/Aruba - but it's a slow process because the behaviour is so odd.
Currently, no AP's receive config updates. They're still showing as online in Central and we've confirmed they can communicate from our network to Central. You can change anything in Central and it's just not pushed to the AP's, not even something simple like blinking the locator LED.
To make it more odd, if we power-cycle an AP they lose all config, can't reconnect to Central and are stuck with what looks like a default config. Admittedly we've only seen that with 2 AP's out of the cluster but we're too afraid to test another one because we can't afford to have any more down.
I was wondering if anyone else has seen anything like this? We're starting to think it's down to a bug or something weird in Central rather than anything we've done, partly because we've eliminated almost every possibility on our end, and partly because we discovered another bug with Central about 2 weeks ago with AP configuration.
Anyone else having problems like this? Also - I'm open to thoughts on how to troubleshoot further.
L8r.
