Yes, the system ip is what the gateway uses for communication to the device, also where APs form their tunnels to. It's comparable to the controller-ip in AOS8.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Jan 06, 2025 05:51 AM
Subject: AOS 10 - GW system ip address
Dear Experts,
I cannot understand which ip address shall be the system ip address? in normal legacy controller setup is it the same as controller-ip? because i think this will be the same ip on which APs form tunnel with controller right?
In my typical case, i always have controller ip on Vlan 1 (in lab setup) so shall i configure it to be system ip?
