Hi Ronin,
Unfortunately, the 6000 and 6100 series do not support UBT, it is from the 6200 series onwards that UBT is supported for the tunneling of user traffic from a switch to a gateway.
With the AOS-S 2930 range you can do UBT.
Best Regards
Daniel Ruiz
If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
Original Message:
Sent: Nov 20, 2024 02:23 AM
Subject: AOS 10 UBT with Controller 7005/7010
Dear Experts,
I want to build a lab for AOS 10 with GW 7005/7010 with switch for UBT. I have 6000, 6100 and 2930F. I think 6000/6100 doesnt support UBT, is that true if we are using AOS10? if yes can we do using 2930F?
