  • 1.  AOS 8 VSGs for conductor/controller
    Posted Mar 20, 2025 06:01 PM
    I understand that there is a big push to get AOS 10 based designs out but unfortunately not all customers are there yet. I am tasked with supporting the migration of a Conductorless deployment to a conductor/controller setup. Although I know how to configure this, it would be great if I can reference a Validated Design Guide. When going on the HPE portal I can't find any AOS 8 designs anymore. Are they hidden? Any helpful tips? Consult your Aruba Rep?
    thanks!
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 20, 2025 07:30 PM
    I don't know of anything that was created during the timeframe of early AOS 8 that would apply.  The Fundamentals Guide would have some background information and might be pertinent.
    Is there a specific question that you think a VRD would answer?
    Carson Hulcher, ACEX#110
  • 3.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 21, 2025 08:46 AM
    Thanks Carson,
    It was more a generic question, although applicable to something I am doing.
  • 4.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 21, 2025 12:58 AM
    I suppose you have already checked the videos on Youtube for AOS8 ?
    https://www.youtube.com/watch?v=_1XRm0jZ5mw&list=PLss8dMlpbaMTC7Ync9WzBKKxeGG4ED8uY
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 5.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 21, 2025 02:50 AM
    Here is the link for ArubaOS 8 Fundamentals Guide
  • 6.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 21, 2025 08:48 AM
    Quote from the document: "Aruba Deployment Guides are best practice recommendation documents specifically designed to outline
    how Aruba technology works and to enable customers who deploy Aruba solutions to achieve optimal
    result" Spot on! Thank you all!
  • 7.  RE: AOS 8 VSGs for conductor/controller
    Posted Mar 21, 2025 08:47 AM
    Definitely familiar with the vids, thank you
