  • 1.  AOS 8.10 7280 Cluster issue
    Posted Jul 02, 2023 08:58 AM
    Hello Airheads,
    We are seeing a weird behaviour on a 7280 cluster. We have upgraded from code 8.7.1.11 ,which is working fine, to 8.10.0.6 as 8.7 is going eol. After Upgrade I found that there is random disconnection in the 7280 cluster. I can see some crash event matching the timestamp. Any suggestions?
    #show lc-cluster history
    -------------LEGEND-----------------
    HRPC   - HBT RCVD PEER CONN
    HMPD   - HBT MISS PEER DEAD
    LMRPD  - LINK MAP RCVD PEER DEAD
    IDPD   - IPSEC DOWN PEER DEAD
    CPDPD  - CRIT PROCESS DOWN PEER DEAD
    CDPD   - CLUSTER DISABLED PEER DEAD
    Cluster History
    TIME                     IPv4 Address     STATUS      REASON
    Sat Jul  1 15:30:23 2023 x.x.x.x CONNECTED    HRPC
    Sun Jul  2 09:56:04 2023 x.x.x.x DISCONNECTED CPDPD
    Sun Jul  2 09:57:50 2023 x.x.x.x CONNECTED    HRPC
    Sun Jul  2 18:41:12 2023 x.x.x.x DISCONNECTED CPDPD
    Sun Jul  2 18:42:57 2023 x.x.x.x CONNECTED    HRPC
    #show crashinfo
    Crash Info Table
    Crash Time              Process Name
    July 02 09:56           auth
    July 02 18:41 auth
    Jul  2 09:56:16 2023  stm[15462]: PAPI_Security: Denying message 0 received from unauthenticated source x.x.x.x:8225 for PAPI port 8419
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da8f opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da92 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da95 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da98 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da9b opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000da9e opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000daa1 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000daa4 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000daa7 opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000daab opcode=0x17
    Jul  2 09:56:16 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x0000daaf opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055c9 opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI_Security: Denying message 0 received from unauthenticated source x.x.x.x:8225 for PAPI port 8419
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055cc opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055cf opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055d3 opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055d6 opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055d9 opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055dc opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055df opcode=0x17
    Jul  2 18:41:21 2023  stm[15462]: PAPI RxPacketFromSibyte: ACK to invalid packet SN = 0x000055e2 opcode=0x17
  • 2.  RE: AOS 8.10 7280 Cluster issue
    Posted Jul 02, 2023 10:47 PM
    You have a connectivity issue between your cluster members and your conductor.
    I would check to make sure you don't have a duplicate ip address in your network.
    I would do a basic ping to your conductor from the wired network and your Mds from the wired network to see if any pings drop.  If they do, you have to troubleshoot a basic connectivity issue like, duplicate ip address or bad patch cabling.  I would also look at the port statistics on the interfaces where your controllers connect to your switches.
    What is the device at the x.x.x.x ip address?
  • 3.  RE: AOS 8.10 7280 Cluster issue
    Posted Jul 03, 2023 01:23 AM
    There is no ping drop between the Conductors and the MDs, basic checks have been done and there is no clues showing any poacket loss. The cluster is working well in version 8.7 but after upgrade we start to see auth process crashes and cluster disconnect events.
    x.x.x.x ip address is the other controller in the cluster.
  • 4.  RE: AOS 8.10 7280 Cluster issue
    Posted Jul 09, 2023 10:13 PM
    Seems we are hitting a bug found in version 8.10.0.5 causing auth process crash. After upgrading to version 8.10.0.7, the issue is resolved.
