One question @ end of this post.
Re: AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks
The AOS-X manuals mention SUBNET-MASK when discussing ACL/ACE.
The following SYSTEMS use network Access-List WILDCARD Masking:
HP PRocurve
HPE Provision
ArubaOS Switch
Cisco
It appears HPE ArubaOS-CX uses SUBNET-MASK and not wildcarding:
A.B.C.D Specify source IP host address
A.B.C.D/M Specify source IP network address with prefix length
A.B.C.D/W.X.Y.Z Specify source IP network address with network mask
NAME Specify source IP address group
any Any source IP address
QUESTION:
HPE AOS-CX ACL MASKING is just opposite of the previosly mentioned SYSTEMS? Is my interpretation correct???
thanks...gracias....danke....merci
