Updates have been pushed to both the AOS-CX Ansible
Collection and
Role that include dependency on the Python3 package
pyaoscx v2 .
All modules that use REST API will utilize the pyaoscx v2 library to execute REST API calls and validate device configuration allowing for even more efficient execution!
Our previous implementation will continue to function but will not be supported for future modules. That means you need to update your Ansible Inventory variables to specify the following:
ansible_network_os=arubanetworks.aoscx.aoscx
when using the AOS-CX Ansible Collection or ansible_network_os=aoscx
when using the AOS-CX Ansible Role
ansible_aoscx_validate_certs
: Set to True
or False
depending if Ansible should bypass validating certificates to connect to AOS-CX. Only required when ansible_connection
is set to aoscx
ansible_aoscx_use_proxy
: Set to True
or False
depending if Ansible should bypass environment proxies to connect to AOS-CX. Only required when ansible_connection
is set to aoscx
Refer below for the command to update to the latest collection or role:
ansible-galaxy install arubanetworks.aoscx_role -f ansible-galaxy collection install arubanetworks.aoscx -f------------------------------
Tiffany Chiapuzio-Wong
