The objective of this post is to help understand and discuss AOS-CX IPv6 - Link Local Addresses.
Part 1 can be found here
https://community.arubanetworks.com/discussion/aos-cx-ipv6-link-local-addresses?ReturnUrl=%2fcommunity-home%2fdigestviewer%3fcommunitykey%3d22dc38ea-a1e1-4059-b55e-a622fedecf32LLAs can also be used for routing, the main benefit is: network admins no longer have to deal with IPv6 subnet planning for the routed inter switch links.
Just enable dynamic LLA on these links and routing peers can be established.
You could utilize static LLA if you wanted deterministic IPs.
We will use this topology and OSPFv3/IBGP in our example.
As OSPFv3/BGP requires an IPv4 router ID, each switch has Lo0 with a /32 IPv4 address assigned to it for this purpose.
GUA /128 IPv6 addresses are added to the same loopbacks to verify IPv6 routing.
Here are configs for each AOS-CX switch, you will notice it's simpler (compared to IPv4 OSPFv2) as the only IPs are loopback related.
Switch1
interface 1/1/4
no shutdown
ipv6 address link-local
ipv6 ospfv3 1 area 0.0.0.0
interface loopback 0
ip address 192.168.1.1/32
ipv6 address 2001:db8:beef::1/128
router ospfv3 1
router-id 192.168.1.1
area 0.0.0.0
Switch2
interface 1/1/49
no shutdown
interface 1/1/50
no shutdown
ip address 192.168.1.2/32
ipv6 address 2001:db8:beef::2/128
router ospfv3 1
router-id 192.168.1.2
area 0.0.0.0
Switch3
interface 1/1/4
no shutdown
ip address 192.168.1.3/32
ipv6 address 2001:db8:beef::3/128
router ospfv3 1
router-id 192.168.1.3
area 0.0.0.0
We verify OSPFv3 neighbors come up as expected, IPv4 neighbor ID is seen, while neighbor address is LLA.
Switch2# sh ipv6 ospfv3 nei
VRF : default Process : 1
Total Number of Neighbors: 2
Neighbor ID Priority State Interface
192.168.1.1 1 FULL/BDR 1/1/49
Neighbor address fe80::5480:2801:10fe:f900
192.168.1.3 1 FULL/DR 1/1/50
Neighbor address fe80::5480:2801:10fe:2900
GUA routes are advertised and learnt as expected with LLA as nexthop.
Switch1# sh ipv6 route
Displaying ipv6 routes selected for forwarding
Origin Codes: C - connected, S - static, L - local
R - RIP, B - BGP, O - OSPF
Type Codes: E - External BGP, I - Internal BGP, V - VPN, EV - EVPN
IA - OSPF internal area, E1 - OSPF external type 1
E2 - OSPF external type 2
VRF: default
Prefix Nexthop Interface VRF(egress) Origin/ Distance/ Age
Type Metric
2001:db8:beef::1/128 - loopback0 - L [0/0] -
2001:db8:beef::2/128 fe80::9020:c201:c4ba:d800 1/1/4 - O [110/1] 00h:03m:58s
2001:db8:beef::3/128 fe80::9020:c201:c4ba:d800 1/1/4 - O [110/2] 00h:03m:49s
Total Route Count : 3
Pings between loopbacks work as expected.
Switch1# ping6 2001:db8:beef::3 source 2001:db8:beef::1
PING 2001:db8:beef::3(2001:db8:beef::3) from 2001:db8:beef::1 : 100 data bytes
108 bytes from 2001:db8:beef::3: icmp_seq=1 ttl=63 time=0.179 ms
108 bytes from 2001:db8:beef::3: icmp_seq=2 ttl=63 time=0.180 ms
Traceroute output from Switch1 to Switch3 display loopbacks, this helps view the path/routers used.
Switch1# traceroute6 2001:db8:beef::3
traceroute to 2001:db8:beef::3 (2001:db8:beef::3) from 2001:db8:beef::1, 30 hops max, 3 sec. timeout, 3 probes, 24 byte packets
1 2001:db8:beef::2 (2001:db8:beef::2) 0.2573 ms 0.2376 ms 0.1277 ms
2 2001:db8:beef::3 (2001:db8:beef::3) 0.1701 ms 0.1899 ms 0.1135 ms
For IBGP, loopbacks are recommended for peering.
Since loopbacks are advertised and learnt via OSPFv3, we can establish IBGP between Switch1 and Switch3 using loopbacks as both source/destination.
Switch1# sh run bgp
router bgp 65001
bgp router-id 192.168.1.1
neighbor 2001:db8:beef::3 remote-as 65001
neighbor 2001:db8:beef::3 update-source loopback 0
address-family ipv6 unicast
neighbor 2001:db8:beef::3 activate
Switch3# sh run bgp
router bgp 65001
bgp router-id 192.168.1.3
neighbor 2001:db8:beef::1 remote-as 65001
neighbor 2001:db8:beef::1 update-source loopback 0
neighbor 2001:db8:beef::1 activate
We verify IBGP is establised between Switch1 and Switch3.
Switch1# sh bgp ipv6 unicast summary
Codes: * Dynamic Neighbor
VRF : default
BGP Summary
Local AS : 65001 BGP Router Identifier : 192.168.1.1
Peers : 1 Log Neighbor Changes : No
Cfg. Hold Time : 180 Cfg. Keep Alive : 60
Confederation Id : 0
Neighbor Remote-AS MsgRcvd MsgSent Up/Down Time State AdminStatus
2001:db8:beef::3
65001 3 3 00h:00m:18s Established Up
You might be wondering if LLA can be used for EBGP.
The answer is no, as seen below.
Switch1(config)# router bgp 65001
Switch1(config-bgp)# neighbor fe80::2 remote-as 65002
Link local address is not allowed for neighbor configuration
If you have questions, let's discuss!
DWan
