Wired Intelligent Edge
AOS-CX Simple Route redistribution OSPF-BGP!
  • 1.  AOS-CX Simple Route redistribution OSPF-BGP!
    Posted Jul 22, 2020 01:03 PM
    Good day!
    AOS-CX Route Redistribution
    Route redistribution is a process that allows a network to use a routing protocol to dynamically route traffic based on information learned from a different routing protocol like OSPF and BGP. Route redistribution helps increase accessibility and control routes within networks.
    AOS-CX 10.5 Sample Topology
    Step1: Let's configure BGP-CORE
    hostname BGPCORE
    !#Configure LAG11 to ASBR-1
    interface lag 11
        no shutdown
        ip address 172.16.0.1/30
        lacp mode active
    interface 1/1/1
        no shutdown
        lag 11
    interface 1/1/2
        no shutdown
        lag 11
    !#Configure LAG12 to ASBR-2
    interface lag 12
        no shutdown
        ip address 172.16.0.5/30
        lacp mode active
    interface 1/1/3
        no shutdown
        lag 12
    interface 1/1/4
        no shutdown
        lag 12
    !#Configure Loopback
    interface loopback 0
        ip address 172.31.0.1/32
    !#Configure BGP AS 65010
    router bgp 65010
        neighbor 172.16.0.2 remote-as 65011
        neighbor 172.16.0.6 remote-as 65011
        address-family ipv4 unicast
            neighbor 172.16.0.2 activate
            neighbor 172.16.0.6 activate
            network 172.16.0.0/30
            network 172.16.0.4/30
            network 172.31.0.1/32
        exit-address-family
    Step2: Configure ASBR-1
    hostname ASBR-1
    !#Configure OSPF and BGP
        ip address 1.1.1.1/32
        ip ospf 1 area 0.0.0.0
    router ospf 1
        router-id 1.1.1.1
        bfd all-interfaces
        redistribute bgp
        area 0.0.0.0
    router bgp 65011
        neighbor 172.16.0.1 remote-as 65010
            neighbor 172.16.0.1 activate
            neighbor 172.16.0.1 next-hop-self
            redistribute ospf
        exit-address-family
    !#Configure Lag1 between ASBR’s
    interface lag 1
        no shutdown
        ip address 10.0.1.1/30
        lacp mode active
        ip ospf network point-to-point
    interface 1/1/3
        no shutdown
        lag 1
    interface 1/1/4
        no shutdown
        lag 1
    !#Configure Lag11 to BGP-CORE
    interface lag 11
        no shutdown
        ip address 172.16.0.2/30
        lacp mode active
    interface 1/1/1
        no shutdown
        lag 11
    interface 1/1/2
        no shutdown
        lag 11
    !#Configure OSPF-1 and OSPF-2 connected interface
    interface 1/1/5
        no shutdown
        ip address 10.0.1.5/30
    interface 1/1/6
        no shutdown
        ip address 10.0.1.9/30
    Step3: Configure ASBR-2
    hostname ASBR-2
        ip address 1.1.1.2/32
    router ospf 1
        router-id 1.1.1.2
        bfd all-interfaces
        redistribute bgp
        area 0.0.0.0
    router bgp 65011
        neighbor 172.16.0.5 remote-as 65010
            neighbor 172.16.0.5 activate
            neighbor 172.16.0.5 next-hop-self
            redistribute ospf
        exit-address-family
    interface lag 1
        no shutdown
        ip address 10.0.1.2/30
        lacp mode active
    interface 1/1/3
        no shutdown
        lag 1
    interface 1/1/4
        no shutdown
        lag 1
    !#Configure Lag12 to BGP-CORE
    interface lag 12
        no shutdown
        ip address 172.16.0.6/30
        lacp mode active
    interface 1/1/1
        no shutdown
        lag 12
    interface 1/1/2
        no shutdown
        lag 12
    interface 1/1/5
        no shutdown
        ip address 10.0.1.13/30
    interface 1/1/6
        no shutdown
        ip address 10.0.1.17/30
    Step4: Configure OSPF-1
    hostname OSPF-1
    !#Configure Loopback and OSPF
        ip address 1.1.2.1/32
    router ospf 1
        router-id 1.1.2.1
        area 0.0.0.0
    !#Configure OSPF on connected interface
    interface 1/1/1
        no shutdown
        ip address 10.0.1.6/30
    interface 1/1/2
        no shutdown
        ip address 10.0.1.14/30
    Step5: Configure OSPF-2
    hostname OSPF-2
    !#Configure loopback and OSPF
        ip address 1.1.2.2/32
    router ospf 1
        router-id 1.1.2.2
        bfd all-interfaces
        area 0.0.0.0
    interface 1/1/1
        no shutdown
        ip address 10.0.1.10/30
    interface 1/1/2
        no shutdown
        ip address 10.0.1.18/30
    VERIFICATION:
    ASBR-1# show lldp neighbor-info
     LLDP Neighbor Information
    Total Neighbor Entries          : 5
    Total Neighbor Entries Deleted  : 0
    Total Neighbor Entries Dropped  : 0
    Total Neighbor Entries Aged-Out : 0
    LOCAL-PORT  CHASSIS-ID         PORT-ID          PORT-DESC               TTL      SYS-NAME
    1/1/1       08:00:09:21:4c:e9  1/1/1            1/1/1                   120      BGPCORE
    1/1/2       08:00:09:21:4c:e9  1/1/2            1/1/2                   120      BGPCORE
    1/1/3       08:00:09:a8:58:d4  1/1/3            1/1/3                   120      ASBR-2
    1/1/4       08:00:09:a8:58:d4  1/1/4            1/1/4                   120      ASBR-2
    1/1/5       08:00:09:04:b6:52  1/1/1            1/1/1                   120      OSPF-1
    ASBR-1#
    ASBR-1# sh ip ospf 1 routes
    Codes: i - Intra-area route, I - Inter-area route
           E1 - External type-1, E2 - External type-2
    OSPF Process ID 1 VRF default, Routing Table
    Total Number of Routes : 10
    1.1.1.2/32         (i) area: 0.0.0.0
         via 10.0.1.2 interface lag1, cost 50 distance 110
    1.1.2.1/32         (i) area: 0.0.0.0
         via 10.0.1.6 interface 1/1/5, cost 100 distance 110
    10.0.1.0/30        (i) area: 0.0.0.0
         directly attached to interface lag1, cost 50 distance 110
    10.0.1.4/30        (i) area: 0.0.0.0
         directly attached to interface 1/1/5, cost 100 distance 110
    10.0.1.8/30        (i) area: 0.0.0.0
         directly attached to interface 1/1/6, cost 100 distance 110
    10.0.1.12/30       (i) area: 0.0.0.0
         via 10.0.1.2 interface lag1, cost 150 distance 110
    10.0.1.16/30       (i) area: 0.0.0.0
    172.16.0.0/30      (E2)
         via 10.0.1.2 interface lag1, cost 25 distance 110
    172.16.0.4/30      (E2)
    172.31.0.1/32      (E2)
    ASBR-1#
    Reference:
    https://techhub.hpe.com/eginfolib/Aruba/OS-CX_10.04/5200-6702/index.html#book.html
    Thank you,
    Yash
