AOS-CX Switch Simulator
AOS-CX Simulator Lab - NetEdit 2.1 Part 4
This thread has been viewed 194 times
  Thread closed by the administrator, not accepting new replies.
  • 1.  AOS-CX Simulator Lab - NetEdit 2.1 Part 4
    Posted Jun 15, 2021 10:55 AM
    No replies, thread closed.
    Objective
    This is the fourth part  of a NetEdit lab series. At the end of the lab series, you will be able to operate an Aruba AOS-CX Network using Aruba NetEdit 2.1.
    In this lab you will create a NetEdit Notification and Deploy an NAE Agent, then you will test the NetEdit NAE status monitoring function including the notification log.
    Materials
    In the attachments you will find:
    • Overview Video
    • Lab Guide
    • EVE-NG Lab Import File
