Hello All
I am running the AOS-CX Virtual 10.07.0010 in Eve-NG 4.0.1-50-PRO.I tried running the Lab that was posted yesterday by Ruben.Iglesias (by the way I VERY much apperciate the time and effort that is invested in creating these labs). I got as far as the steps in Task 4 were you run the debug to find the miss configured IP address. and I am not getting the "Source IP address = 192.168.10.0" err. I am getting a LOT of hardware errors.
switch# sh debug
Not configured
switch# debug ospfv2 all
switch# show debug buffer
show debug buffer
2021-07-29:00:30:45.333919|mcast-debugd|LOG_ERR|AMM|-|MTRACE|MTRACE|Remove all_mtrace ovsdb entries on restart
2021-07-29:00:30:46.401899|aaautilscfgd|LOG_ERR|AMM|-|AAA|AAA_EVENT|hdf_inotify_listener_add_monitored_file failed
2021-07-29:00:30:46.401923|aaautilscfgd|LOG_ERR|AMM|-|AAA|AAA_EVENT|hdf_inotify_listener_add_monitored_file failed
2021-07-29:00:30:54.112547|hpe-mgmtmd|LOG_ERR|AMM|-|MGMTMODULE|MGMTMODULE_CONTROL|Could not open file '': No such file or directory
2021-07-29:00:30:54.112654|hpe-mgmtmd|LOG_ERR|AMM|-|MGMTMODULE|MGMTMODULE_CONTROL|mmap_file() failed
2021-07-29:00:30:54.112668|hpe-mgmtmd|LOG_ERR|AMM|-|MGMTMODULE|MGMTMODULE_CONTROL|Error reading image info for active image -1
2021-07-29:00:30:54.891122|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:30:55.526306|hpe-sysmond|LOG_ERR|AMM|-|SYSMON|SYSMON_CONFIG|Failed to capture amount of data written to coredump_partition_write_since_boot partition since boot
2021-07-29:00:30:55.527524|hpe-sysmond|LOG_ERR|AMM|-|SYSMON|SYSMON_CONFIG|Fail to read sector size
2021-07-29:00:31:00.103615|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:05.210615|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:05.389756|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:05.403516|tunneld|LOG_ERR|AMM|-|VXLAN|VXLAN|tunneld_get_port_row_from_name: port row not found
2021-07-29:00:31:05.403589|tunneld|LOG_ERR|AMM|-|VXLAN|VXLAN|get_cpu_rx_row_by_from: cpu rx row not found for VXLAN-Global
2021-07-29:00:31:05.448569|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:05.639438|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:06.833839|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:07.699885|ops-switchd|LOG_ERR|||||Subsystem C&C load failed: Invalid agent_id
2021-07-29:00:31:07.716578|powerd|LOG_ERR|AMM|-|PWRMGMT|PWRMGMT_READ|Invalid PSU count for chassis-1
2021-07-29:00:31:07.820103|bfdd|LOG_ERR|AMM|-|BFD|BFD_SESSION|An HSC value was not specified [-1][-1][-1][-1]
-- MORE --, next page: Space, next line: Enter, quit: q
There are errors in there about power supply counts, sector size, file open errors (again I think HDD related) etc.
I deleted the imported lab, and tried to just build it out manually, and again exact same thing. Like EXACT.
Anyone seen this before in an emulator?
Any advise would be appreciated
Daniel Worden
