AOS-CX Simulator Lab- Quick Checklist!
Once you load readymade EVE-NG lab (UNI file) on to your EVE environment, please check VPCS ip addresses.
Please configure respective ip address after check show running configuration on connected CX device.
Step1 on VPCS:
Step2: Check connected vlan IP address on AOS-CX switch as below:
Step3: Configure right IP address on VPCS as below:
Step4: Confirm same using packet capture on AOS-CX:
Above QuickChecklist will help labs like below, where we make use of clients as VPCS.
Good day!
Yash NN
