AOS-CX Switch Simulator
  • 1.  AOS-CX Simulator Lab - Quick Packet Capture!
    Posted Apr 19, 2021 02:52 AM
    Packet capture is made so easier on EVE-NG.
    Step1: Build your lab or make use of readymade labs available.
    Step2: Start all the devices
    Step3: Right click on any devices (including a CX device), you will see below option:
    Step4: Click on Capture to start Wireshark capture as below:
    Good day!
    Yash NN
  • 2.  RE: AOS-CX Simulator Lab - Quick Packet Capture!
    Posted Apr 19, 2021 11:23 AM
    Take note "Wireshark integrated" is not available on all EVE-NG versions
    Please refer to https://www.eve-ng.net/index.php/features-compare/
    DWan
