Wired Intelligent Edge
AOS-CX Switch Simulator 10.13 + EVE-NG / virtual switch doesn't start
This thread has been viewed 26 times
  • 1.  AOS-CX Switch Simulator 10.13 + EVE-NG / virtual switch doesn't start
    Posted Dec 15, 2023 12:17 PM
    Hi everyone,
    I have this issue and hope someone can help me.
    I installed AOS-CX 10.13 in EVE-NG environment on VMWARE VM: all it seems OK but when I start the switch it stop immediatly.
    I have the same problem even if I use old AOS-CX versions and if I use others environments (GNS3, VirtualBox ecc...)
    The VMWare setup is: 12Gb RAM - 6 CPU
    Thankyou in advance.
    Best regards
    Daniele
  • 2.  RE: AOS-CX Switch Simulator 10.13 + EVE-NG / virtual switch doesn't start
    Posted Dec 16, 2023 03:55 AM
    Solved by myself.
    I am writing the solution to this problem here in case anyone else is facing this problem.
    The VM (VMWare or VirtualBox) must run nested VMs, it is mandatory.
    So if you are having problems, disable and uninstall Hyper-V on your Windows computer to use Intel VT-x/EPT
