Cloud Managed Networks
AOS10 SD Branch or VPNC for VIA?
This thread has been viewed 51 times
  • 1.  AOS10 SD Branch or VPNC for VIA?
    Posted Jan 17, 2025 03:33 PM
    Dear Experts,
    Does SD Branch persona in AOS10 supports VIA clients?
  • 2.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 17, 2025 04:59 PM
    Edited by mkk Jan 17, 2025 05:00 PM
    In SD-Branch solution the VIA clients are connected to a gateway with the VPNC concentrator persona.
    See also https://www.youtube.com/watch?v=uy6T3MwXgIg
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 17, 2025 05:05 PM
    yes it is support and requires no extra licenses or subscriptions.
  • 4.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 10:29 AM
    Just to confirm, if i am using gateway as branch gateway persona to provide WLAN functionality as well as WAN, will it support VIA clients?
  • 5.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 04:11 PM
    Edited by mkk Jan 21, 2025 02:35 AM
    Via-client is only supported in the "VPN Concentrator" or "Branch" persona.
    -edit-
  • 6.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 04:46 PM
    Yes as MKK mentioned VIA needs VPN concentration or branch gateway persona and is part of SD-WAN features
    check the Central subscription ordering guide that explains it, look for table 8.
  • 7.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 04:58 PM
    Dear Ariya
    You mentioned vpnc or branch gateway persona, mkk said only vpnc. So can you confirm if it can be supported in branch gateway persona?
  • 8.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 05:23 PM
    See also the VIA solution guide. https://www.arubanetworks.com/techdocs/central/sd-branch-ref-docs/via-remote-access-solution-guide.pdf
  • 9.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 05:32 PM
    Edited by mkk Jan 21, 2025 02:36 AM
    -removed-
  • 10.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 20, 2025 07:05 PM
    Just note that client VPN (VIA) is supported on any gateway with foundational, foundational-base etc subscription. The gateway can take the persona of VPNC or branch gateway.
    It is outlined in the current  Central subscription ordering guide that I shared, you can talk to your local Aruba system engineer to get the details.
  • 11.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 21, 2025 02:34 AM
    Because I started to doubt myself and couldn't clearly find the information in the documentation, I checked with our Aruba SE this morning. He confirmed that the VIA Client can also be configured in the "Branch" persona. Learned something new today!
    Thanks for the heads up Ariyap!
  • 12.  RE: AOS10 SD Branch or VPNC for VIA?
    Posted Jan 21, 2025 01:09 PM
    Thanks Marcel and Ariya, Appreciate your support
