Hi Rushit
You can look the developer portal for AOS 8 : https://developer.arubanetworks.com/aruba-aos/docs/about
and also the "swagger" https://developer.arubanetworks.com/aruba-aos/reference/ (there is a swagger directly on the controller)
but the command is more for Get and Set Configuration, for "monitoring", you need to use showcommand
the good point, the show command return often json result
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Apr 08, 2025 08:35 AM
Subject: AOS8 APIs for getting Controller, APs, Clients, and links between APs and client details
I'm currently working with the ArubaOS 8 (AOS8) APIs and trying to retrieve details about the following:
I'm aware that the showcommand
APIs can provide this information. However, I'm looking for native or dedicated API endpoints-ideally from internal monitoring or configuration APIs-that expose this data directly, without relying on the execution of CLI-based show commands.
Does anyone know if such APIs exist in AOS8? If so, could you point me to the right endpoints or documentation?
Any help would be greatly appreciated!
Thanks in advance.
