  • 1.  AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 13, 2024 07:01 AM
    I am currently trying to understand the general traffic flow within a cluster. I could see that APs build the typical 4 tunnels (AAC/S-AAC/UAC/S-UAC) and that the UAC tunnel is build per BSSID as well as only one tunnel for each client connected to said SSID.
    However I was just troubleshooting a situation where a controller uplink was saturated. I checked the client/AP distribution in the cluster and saw this.
    Cluster Load Distribution for APs
    Type IPv4 Address    Active APs     Standby APs
    self       x.x.x.x             30              69
    peer       y.y.y.y             69              30
    Total: Active APs 99 Standby APs 99
    Cluster Load Distribution for Clients
    Type IPv4 Address    Active Clients Standby Clients
    self       x.x.x.x             20            1219
    peer       y.y.y.y           1220              20
    The cluster balancing settings were left to default, which at least explains why it did not put effort in rebalancing them. I don't understand why it did not do the initial 1% balancing.
    This is the bucket map for the ESSID. It is an 80:20 split for reason I did not yet find out.
    Active Map[0-31]      01 01 01 01 01 00 01 01 00 01 01 01 01 00 01 01 00 01 01 01 01 01 01 01 00 00 01 00 01 01 01 01
    Active Map[32-63]     01 00 01 01 01 01 01 01 01 01 01 01 00 00 01 01 01 01 00 01 01 01 01 00 01 01 01 01 01 01 00 01
    Active Map[64-95]     01 00 01 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 00 00 01 00 00 01 01 01 01 01 00 01 01 01
    Active Map[96-127]    01 00 01 01 00 01 01 00 00 01 01 00 01 01 01 01 01 01 01 01 01 01 01 00 01 00 01 01 01 00 01 01
    Active Map[128-159]   01 01 01 01 01 01 01 00 01 01 00 01 01 01 01 00 01 01 01 01 01 01 01 00 01 01 01 00 01 01 01 01
    Active Map[160-191]   01 00 01 01 01 01 01 00 01 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 01 01 00 01
    Active Map[192-223]   01 01 01 01 01 01 00 01 00 01 01 01 01 01 01 00 01 01 01 01 01 01 01 01 00 00 01 01 01 01 01 01
    Active Map[224-255]   00 01 01 01 01 01 01 01 01 00 01 00 01 01 01 01 01 00 01 01 01 01 01 01 01 00 01 01 01 00 00 01
    Standby Map[0-31]     00 00 00 00 00 01 00 00 01 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 01 01 00 01 00 00 00 00
    Standby Map[32-63]    00 01 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 00 00 01 00
    Standby Map[64-95]    00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 01 01 00 00 00 00 00 01 00 00 00
    Standby Map[96-127]   00 01 00 00 01 00 00 01 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 01 00 00
    Standby Map[128-159]  00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 00
    Standby Map[160-191]  00 01 00 00 00 00 00 01 00 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 01 00
    Standby Map[192-223]  00 00 00 00 00 00 01 00 01 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00
    Standby Map[224-255]  01 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 01 01 00
    None of those however explain how it is possible that the seemingly less utilized controller had a saturated uplink. That is why I want to understand the traffic flow between cluster members.
    Does anyone know more details?
    Thanks in advance
  • 2.  RE: AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 13, 2024 12:33 PM
    What model controllers are you using?  What version of AOS 8?
    Carson Hulcher, ACEX#110
  • 3.  RE: AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 14, 2024 02:19 AM
    It is a cluster comprised of 2 7210 controllers running 8.10.0.12 LSR
  • 4.  RE: AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 14, 2024 05:09 AM
    That is weird... with equal platforms the distribution is expected to be roughly 50-50 (for 2 controllers); it's quite offset.
    Cluster health looks further good? vlan-probes, heartbeat counters, etc? If you are not comfortable troubleshooting yourself, I would work with TAC on this to find what is causing this unbalance.
  • 5.  RE: AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 14, 2024 07:55 AM
    They are regularily heartbeating and it is L2 connected. In the meantime the controller was rebooted and the balancing parameters were adapted to accommodate the actual used AP/client count.
    Looks ok again so far.
    I am trying to understand how the controllers are determining the split ratio per ESSID now. I checked the ESSIDs and they differ from each other.
    49:51
    50:50
    46:54
    47:53
    35:65
    Out of curiosity I connected to another cluster that never had those issues. There I can also see unequal split ratios (different platform same software version). Is there any documentation on how those are derived? I was under the impression that the ratio is based on the number of controllers in a cluster and not some seemingly arbitrary number. I also cannot find specifics in the book "Understanding AOS8" by @westcott
    Regarding TAC, I consider it once I cannot find any further information that is available or can be shared publicly.
  • 6.  RE: AOS8 Clustering AAC/UAC Traffic Flow
    Posted Nov 14, 2024 09:43 AM
    I would recommend going ahead with the TAC case, that behavior isn't what we expect.
