  • 1.  [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 10:42 AM
    Hi Everyone,
    I have an issue with admin password recovery in AOS8.
    When i don't know password of MC, I just try to chage it.
    CLI
    User: password
    Pass: forgetme!
    "Try to config mode"
    (Aruba7005) *#configuer terminal
    This controller is manage by a MM.
    Configuration change can only be performed on the MM.
    "Try to wri erese all"
    (Aruba7005) *#write erese all
    yes
    You do not have permission to execute this command.
    Help me factory default my 7005 with aos8 please.
    TQ.
  • 2.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 10:44 AM
    Since the controller is managed by a mobility manager currently, you'll need to jump to disaster recovery mode on that controller to enable to local config changes:
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/Disaster-Recovery-feature-on-AOS-8-x/ta-p/290922
  • 3.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 10:54 AM
    I can't use disaster-recovery on command.
    Because don't have permission execute this command.
  • 4.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 10:59 AM
    You need to log in to the MD to execute the hidden command "local-config enable", and then execute the command mgmt-user admin root.
  • 5.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 11:02 AM
    Great!!!!!!
    It's worked!!
    Thank you..
  • 6.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Need to go into disaster recovery mode
    (BOSTON-MC-1) #disaster-recovery
    off Disable Disaster Recovery Mode
    on Enable Disaster Recovery Mode
    And then change the password
    Sent from Mail for Windows 10
  • 7.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 10:50 AM
    I try to
    (7005) *# disaster-recovery on
    you don't have permission to execute this command.
  • 8.  RE: [AOS8-MC] Admin password recovery and Factory default.
    Posted Aug 09, 2018 11:04 AM
    I've already change admin password and reset everythings.
    thank you all of you.
    good day.
