  • 1.  AP-135 reset problems
    Posted Aug 14, 2012 05:23 PM
    Hello, I am having some difficulty doing a reset on a AP-135. I have attached log file. Any help would be greatly appreciated.
    Attachment(s)
    txt
    AP_135.txt   5 KB 1 version
  • 2.  RE: AP-135 reset problems
    Posted Aug 14, 2012 05:50 PM
    This AP 135 is an IAP and it is joining the IAP cluster. Are you trying to use this AP as a campus AP?
  • 3.  RE: AP-135 reset problems
    Posted Aug 14, 2012 05:54 PM
    Yes, that is the plan. I need to reset back to factory defaults. My initial vlan setup was incorrect, and now I cant connect or access WebUI.
  • 4.  RE: AP-135 reset problems
    Posted Aug 14, 2012 06:00 PM
    In that case, you will have to convert the IAP into a campus AP.
    1.Connect the AP to a separate subnet so that it will come up as the virtual master and you can log into the web UI of the AP.
    2. Maintenance -> Convert
    Convert one of more Access Points t0:
    Campus APs managed by a Mobility Controller
    -> Enter IP address of the Mobility controller
    -> Hit Convert Now.
    You should see the AP come up on your controller.
  • 5.  RE: AP-135 reset problems
    Posted Aug 14, 2012 06:07 PM
    Thanks, I will give it a shot. That worked, Thanks You very much!
