Community Feedback
  • 1.  AP 203RP does not work after factory reset
    Posted Feb 12, 2025 05:50 AM
    I have old 203RP with US regional. I try to flash it to RW version with console cable. However before reset the AP, I put command factory_reset in putty then the AP boot but cannot get IP from DHCP. How can I recover it? Thx U
  • 2.  RE: AP 203RP does not work after factory reset
    Posted Feb 12, 2025 08:07 PM
    You can see in this link the commands that you can use in the boot process to configure a static IP for the AP. Do you know the firmware versión? I mean, this AP is in Instant mode or CAP?
    https://arubanetworking.hpe.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/AP_Config/AP_Console_Settings.htm
    Best Regards
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 3.  RE: AP 203RP does not work after factory reset
    Posted Feb 13, 2025 01:56 PM
    You cannot 'flash' an US accesspoint to RW. Trying to do so may make the AP unrecoverable and violates radio regulations.
