  • 1.  [AP 225 , AP275] second ethernet Port Questions
    Posted Feb 28, 2015 07:46 AM
    Dear All,
    can we use the second Ethernet Port of the AP 225 and 275 as an uplink to other  AP , or we can just use it for aggeregation ?
    Regards
    #AP225
  • 2.  RE: [AP 225 , AP275] second ethernet Port Questions
    Posted Feb 28, 2015 08:38 AM
    No, you should not daisy chain APs.
    Tim
  • 3.  RE: [AP 225 , AP275] second ethernet Port Questions
    Posted Feb 28, 2015 10:20 AM
    Hi caplari,
    thank you for the feedback,
    but please tell me i can't or i should not ?!
  • 4.  RE: [AP 225 , AP275] second ethernet Port Questions
    Posted Mar 01, 2015 01:22 AM
    The second Ethernet port was not designed for that. It was designed for LACP or failover with spanning tree. It is possible this will do what you want but I have not configured this for any customers.
  • 5.  RE: [AP 225 , AP275] second ethernet Port Questions
    Posted Mar 01, 2015 04:54 AM
    thank you for the replay , yes it was designed for Aggergation with LACP , with that the AP will support up to 2 Gbps uplink wich can handle the traffic (1,3 Gbps +300 Mbps ).
    but i need to know if it is possible or not :).
    Regards
