  • 1.  AP-270-MNT-H1 physical dimensions
    Posted Jan 22, 2020 12:27 PM
    Hi, does anyone know the physical dimensions for AP-270-MNT-H1?
    I'd like to know its weight as well as the base's WxH and the distance between holes (I'm really surprised that such important information is not included in Aruba's Installation Guides for Mounting Kits).
    Thanks in advance.
  • 2.  RE: AP-270-MNT-H1 physical dimensions
    Posted Jan 22, 2020 01:21 PM
    Attached are the documents.
    Attachment(s)
    pdf
    AP-270-MNT-H1 Template.pdf   42 KB 1 version
    pdf
    AP-270-MNT-H1 IG Rev 03.pdf   1.46 MB 1 version
  • 3.  RE: AP-270-MNT-H1 physical dimensions
    Posted Jan 22, 2020 01:25 PM
    Thank you very much for the information! Is there any specific location within Aruba's site where I could look for these and other related files?
  • 4.  RE: AP-270-MNT-H1 physical dimensions
    Posted Jan 22, 2020 01:28 PM
    Yes, there indeed is.
    The old platform is: support.arubanetworks.com (which i still use)
    The MNT-H1 is under:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=28815
    All the best.
  • 5.  RE: AP-270-MNT-H1 physical dimensions
    Posted Jan 22, 2020 01:30 PM
    Already browsing there, thanks a lot!
