  • 1.  AP-275 Antenna Pattern
    Posted Sep 26, 2014 09:04 AM
    For some reason the pattern plots are missing from the AP-275 data sheet.  Does anyone happen to know where I can find the pattern plots?
  • 2.  RE: AP-275 Antenna Pattern
    Posted Sep 26, 2014 09:18 AM
    Here you go
  • 3.  RE: AP-275 Antenna Pattern
    Posted Mar 23, 2015 12:59 PM
    Seth...have the Antenna patterns for the new AP277 made publically available?  Thanks, Randy
  • 4.  RE: AP-275 Antenna Pattern
    Posted Apr 22, 2015 04:55 AM
    Well, as its 80º H x 80º V it should be something in between the AP-ANT-35 and 38, (Antenna Matrix) but it would be helpfull to have the actual pattern.
    Kind regards
    Jan Vidar Rognsvag
  • 5.  RE: AP-275 Antenna Pattern
    Posted Apr 22, 2015 08:31 AM
    Here are the AP277 antenna patterns that I got from my Aruba SEs...Randy
  • 6.  RE: AP-275 Antenna Pattern
    Posted Apr 22, 2015 08:55 AM
    Thanks, I flipped the vertical patterns and combined them for easier overview. Maybe you could upload the original version if you ever receive it.
  • 7.  RE: AP-275 Antenna Pattern
    Posted Jun 03, 2015 08:24 AM
    Can someone confirm, in regards these pattern diagrams, whether the dB value shown refers to the inner or outer ring (the values are shown between two rings).  I have added these patterns within my AirMagnet planner and I think it possible that I'm 5 dB (!) out, given the coverage shown.
  • 8.  RE: AP-275 Antenna Pattern
    Posted Jun 03, 2015 08:50 AM
    The dBi value is placed on the outside of the related circle as the gain of the AP-277 is 6,5 dBi for both bands.
  • 9.  RE: AP-275 Antenna Pattern
    Posted Jun 03, 2015 08:57 AM
    Of course - that makes perfect sense, now you point it out (and I think about it!)
    Fortunately my AirMagnet plots are good then...   :)
    Thanks very much!
