  • 1.  AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 12:36 PM
    How do I check the signal quality of the mesh link of 2 Ap277's.   Users are reporting bad performance on the ethernet link on the other side.
  • 2.  RE: AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 12:38 PM
    show ap mesh neighbors ap-name <name of ap>
  • 3.  RE: AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 12:41 PM
    An ideal value would be?
  • 4.  RE: AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 12:44 PM
    Show ap mesh topology long is also a good command, or look in the controller under Mesh Points and click on the portal and point to get an RSSI value.
    Anything over 20 should be good, but you may want to provide more information (distance, environment, numbers of wired users on the other side, applications in use, etc).
  • 5.  RE: AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 01:58 PM
    2 Poe Powered Axis Cameras are the only two clients... feeding from a hardened switch from the AP eth0 mesh point.  Pretty sure it an allignment issue.  Its about 70 yards apart, same elevation....
    Thanks all.
  • 6.  RE: AP 277 Mesh - Point to Point
    Posted Sep 14, 2015 02:16 PM
    what is the output from show ap mesh neighbors and show ap mesh topology long?
