AP 277 not broadcasting SSID
  • 1.  AP 277 not broadcasting SSID
    Posted Dec 22, 2017 04:12 AM
    Hi All,
    Would like to check if i am missing out anything, have loaded AOS8 on a 7005, AP used is AP277.
    Have sufficient AP licenses, WLAN configured with AP group assigned with a SSID.
    Am able to see the assess point online, but the SSID set is not seen.
  • 2.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 09:00 AM
    How are you powering that access point?  The AP-277 requires high powered (802.3at) POE.  Type show ap tech-support ap-name <name of ap> | begin "Power Status"  on the commandline of the controller.  You would typically need a power injector or if this is poe, you would need to have LLDP enabled on the switchport for the AP to negotiate higher power.
    http://www.arubanetworks.com/assets/ds/DS_AP270Series.pdf
    Also type "show ap database" to see if the access point has flags.
  • 3.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 09:15 AM
    hi joesph,
    i believe the required power of 277 will require 27 watts thereabouts, am powering up using a brocade switch on POE+ , have assigned 30 W of power.
  • 4.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 09:26 AM
    Please type
    That will show you what power the access point thinks it is getting.
  • 5.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 11:02 AM
    this will churn out a whole list of information instead of a single liner? as am not able to identify the amount of power its getting.
  • 6.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 11:06 AM
    Power Status
    ItemValue
    Power Supply: POE-AT
    LLDP Power: 0.0W
    Current Operational State: No restrictions
  • 7.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 11:33 AM
    Then you need to type "show ap database" to see if your AP has any flags.
  • 8.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:06 PM
    c8:b5:ad:c3:4b:14  RWH  277      192.168.50.21  Up 8m:33s  IL     192.168.50.18  0.0.0.0
    It states unlicensed, but none of our eval licenses have been consumed yet.
  • 9.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:18 PM
    Type "show keys" to see the number of licenses you have.
  • 10.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:21 PM
    Licensed Features
    Feature                                             Status
    Access Points                                       0
    RF Protect                                          0
    VPN Server Module                                   4096
    xSec Module                                         0
    Next Generation Policy Enforcement Firewall Module  0
    Advanced Cryptography                               0
    WebCC                                               0
    Beta AP                                             0
    MM-VA                                               0
    MC-VA-RW                                            0
    MC-VA-EG                                            0
    MC-VA-IL                                            0
    MC-VA-JP                                            0
    MC-VA-US                                            0
    VIA                                                 0
    RF Protect                                          ENABLED
    Policy Enforcement Firewall                         ENABLED
    VPN Server                                          ENABLED
    xSec Module                                         DISABLED
    Policy Enforcement Firewall for VPN users           DISABLED
    Advanced Cryptography                               DISABLED
    Maritime Regulatory Domain                          DISABLED
    X86 VM SKU Activate                                 DISABLED
    WebCC                                               DISABLED
    Beta AP                                             DISABLED
    MM-VA                                               DISABLED
    MC-VA-RW                                            DISABLED
    MC-VA-EG                                            DISABLED
    MC-VA-IL                                            DISABLED
    MC-VA-JP                                            DISABLED
    MC-VA-US                                            DISABLED
    VIA                                                 ENABLED
    The eval licenses were input into the mobility controller, but upon retrieving of the command apparantly there were no licenses?
  • 11.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:24 PM
    do note the current OS is AOS8
  • 12.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:31 PM
    Licensed Features
    Feature                                             Status
    Access Points                                       16
    RF Protect                                          16
    xSec Module                                         0
    Next Generation Policy Enforcement Firewall Module  16
    WebCC                                               0
    Beta AP                                             0
    MM-VA                                               0
    MC-VA-RW                                            0
    MC-VA-EG                                            0
    MC-VA-IL                                            0
    MC-VA-JP                                            0
    MC-VA-US                                            0
    VIA                                                 0
    RF Protect                                          ENABLED
    VPN Server                                          ENABLED
    WebCC                                               DISABLED
    Beta AP                                             DISABLED
    MM-VA                                               DISABLED
    MC-VA-RW                                            DISABLED
    MC-VA-EG                                            DISABLED
    MC-VA-IL                                            DISABLED
    MC-VA-JP                                            DISABLED
    MC-VA-US                                            DISABLED
    VIA                                                 ENABLED
    have updated they keys and they are happily inside, but still no ssid, will try to reboot ap.
  • 13.  RE: AP 277 not broadcasting SSID
    Posted Dec 22, 2017 12:46 PM
    it is working now, would conclude license issue. Thanks joseph.
