No really...
You can enable mac filtering... but easy to bypass
Why don't use (Local) MPSK ?
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jun 22, 2021 05:15 AM
Subject: AP-303
Hi guys,
This is my first post in here. I hope you are all well ;)
We have 16 AP-303 in the cluster and somehow one of the network passcodes leaked. The issue this network has over 30 handheld bar code scanners and to go around and change the passcode is a mammoth task.
Is there a way to block these clients without changing the passcode?
I appreciate your help.
Regards
Wessam
Wessam Baroudi
