Hello.
Can you ssh into the access point?
if so, do you have dns resolution? try to ping something.
What firmware is on the AP?
Original Message:
Sent: Jun 09, 2022 05:40 PM
Subject: AP-305 not reporting to Aruba Central
Hi all,
I have an Aruba AP-305 that is not reporting back to Aruba Central. It is sending out Wifi correctly and I can ping it on my network. It is connected to a Netgear GS728TP2 switch. The Switch Port is tagged for the 3 Wifi VLANS and the Management VLAN that the AP gets its IP address from. Any idea what I am missing>? If it helps I also can't get the switch to connect to any internet time servers; maybe there's something blocking certain types of outbound traffic?
