If the radios aren't operating then the usual reason is going to be incomplete configuration. If you really want to reset the radios, just reboot the AP.
Carson Hulcher, ACEX#110
Original Message:
Sent: Feb 11, 2025 06:39 AM
Subject: AP 305 RW - Led radio Down
After configuring an AP 305 RW in VC mode with Static IP address, GRE tunnel to controller, Local SSID (guest and Data) and reboot the AP, I saw the tunnel is up and running but the led status of the AP is off (no SSID broadcasting). I try to found a cli command to shut/shut the radio interface ... how can I check the radio status of this AP and shut/no shut ?
I don't find any option in the GUI.
thks for your help
