  • 1.  AP-375 realistic Distance
    Posted Jul 03, 2018 06:18 PM
    What is a realistic distance for the AP-375 ?
    I was told 200m. Trying to find solid documentation on this.
    The area I am trying to cover is flat and open without obstructions.
    https://www.arubanetworks.com/products/networking/access-points/370-series/
  • 2.  RE: AP-375 realistic Distance
    Posted Jul 03, 2018 06:59 PM
    Hi
    The maximum distance is more depending on the client device then on the AP. And also the desired speed. With long distances the speed drops very fast.
  • 3.  RE: AP-375 realistic Distance
    Posted Jul 03, 2018 08:12 PM
    It really depends on Signal Strength.
    I tried with AP-275 in Ekahau
    At -69dbm, you can get 200m.
    Tx Power on Access Point was 25mW
    Kapil
  • 4.  RE: AP-375 realistic Distance
    Posted Jul 09, 2018 01:43 PM
    I found the chart below.
    Assuming the below I would have a datarate of 216 at -71 or 108 at -76.
    Does this sound accurate ? Any thoughts?
    VHT MCS Index
    Modulation
    Coding
    20MHz40MHz80MHz160MHz
     Data Rate (Mbps)
    Min. SNR (dB)
    Receive Sensitivity (RSSI)
    Data Rate (Mbps)
    Min. SNR (dB)
    Data Rate (Mbps)
    Min. SNR (dB)
    Data Rate (Mbps)
    Min. SNR (dB)
     GI = 800nsGI = 400nsGI = 800nsGI = 400nsGI = 800nsGI = 400nsGI = 800nsGI = 400ns
            18020034-54390433.337-51780866.740-48
            36040034-54780866.737-5115601733.340-48
            54060034-541170130037-51  40-48
     4 Spatial Streams
     0BPSK1/22628.92-8254605-791171308-7623426011-73
     1QPSK1/25257.85-791081208-7623426011-7346852014-70
     2QPSK3/47886.79-7716218012-7435139015-7170278018-68
     316-QAM1/2104115.611-7421624014-7146852017-68936104020-65
     416-QAM3/4156173.315-7032436018-6770278021-641404156024-61
     564-QAM2/3208231.118-6643248021-63936104024-601872208027-57
     664-QAM3/423426020-6548654023-621053117026-592106234029-56
     764-QAM5/6260288.925-6454060028-611170130031-582340260034-55
     8256-QAM3/4312346.729-5964872032-561404156035-532808312038-50
     9256-QAM5/6  31-5772080034-5415601733.337-5131203466.740-48
  • 5.  RE: AP-375 realistic Distance
    Posted Jul 09, 2018 02:50 PM
    The only caveat I see with that chart is that the MCS rates shown indicate 4 spatial streams. In an outdoor environment, 4 spatial streams may be difficult to support at range.
  • 6.  RE: AP-375 realistic Distance
    Posted Nov 07, 2018 09:24 PM
    200m range from a 375 is easily doable with clear line of sight (that is our design margin criteria for outdoor). We've done 600m to a MPB in wide open space. Environment (pathing, noise, etc) all come in to play though. 200m is pretty easily doable though in most all but the worst environments.
